Results 1 to 13 of 25
    Oct 2007
    Anaheim, CA
    Question Wet Bulb measurements
    I have a couple of questions for all of you smart technicians! I appreciate any information you can provide.
    How many technicians are measuring Wet Bulb temperatures? (out of 100 techs, how many measure wet bulb?)
    Where do technicians take these measurements? Inside the building? At the return Grille? In the return duct work? in the return plenum?
    What do you use to measure the wet bulb temperature?
    What do you use the wet bulb measurements for?
    Jul 2000
    NW IL.
    http://www.efficientcomfort.net/Charging&TDchart.pdf
    By measuring the entering dry bulb and wet bulb temperature of the air entering the evaporator and using the charging chart a better job can be done at measuring system performance.
    Measuring system airflow measuring return and supply wet bulb temperatures you can determine the system's btu capacity outline in the steps in Carriers "Service Technicians Handbook."
    Good question.
    Aircraft Mechanical Accessories Technician. The Air Force changed the job title to Air Craft Environmental Systems Technician. But I've decided I'll always be a Mech Acc.
    Have to admit I still use my sling sycrometer I have had for years.
    It may not be as fast but has worked for years so ........ I'm fine with it.
    Have more important things as far as tools to buy then to replace something I know works.
    Guess electronic might be easier then having my little bottle of distilled water & sling ........ but then I know its accurate
    At the return mostly or the return plenum
    Amprobe digital
    TO know the Evp load
    a regular member trying to get info without being a pro...
    Oct 2007
    Anaheim, CA
    How many posts before I am a pro?
    I am a Fieldpiece guy and you guys...the HVAC technicians... are the ones that drive our product development!...I like to gather as much information as possible from you guys because you are the ones that will use our products for a living!
    I like to keep my mouth shut and ears...eyes...open as much as possible. That's why I only have a few posts.
    Mn the state where absolutey nothing is allowed
    are you saying that you work in the R&D at fieldpiece??
    if that is in fact true say it loud and clear here and you'll get more than enough ideas for product development.
    as for pro statues you need to apply. contact the forum mods
    Quote Originally Posted by ault51 View Post
    only 15 posts, so you are there. apply for promembership it may takes a couple days as all the guys on the membership committee are volunteers and work full time jobs as the rest of us do
    how do you become any better if you don't open your mouth and ask???
    Well.......... You use it for charging
    For piston/ fixed metering device systems only!!!!!! IWB x 3 - 80 - Outdoor AMB / 2 = Superheat
    maui
    Quote Originally Posted by aintitfun View Post
    what????
    What cant be done correctly shouldn't be done at all
    maui
    wow I did that calculation several times against a generic charging chart and it came real close every time
    guess you learn something new every day thanks aintitfun
    i use mine for more than that. the formunla you qoute is for superheat but there are other charts for proper air flow that require wet bulb and dry bulb mesurements of the evaperator entering air to calculate supply dry bulb.
    I use a Testo H-2.
    I try to get my wet bulb readings as close to the evaporator coil as possible, even if I have to drill a 1/2" hole in the side of a furnace.
    The hole also doubles as an inspection hole to insert my fiber optic scope to check that the coil is clean.
    I do get lazy at times and just check at a return grill, if I know the return duct system is very tight, but better than 90% of the time I get the reading at the equipment.
    In my area, there are very many homes built with the HVAC equipment in the attic, and a reasonably extensive return duct system, often incorporating a number of floor level returns that pull through wall cavities.
    Checking the WB and DB temps at the coil is not only much more accurate, but it also allows me to spot problems with leaky returns, which are common, or significant leakage around the blower access, which is even more common.
