Results 14 to 22 of 22
    Aug 2005
    Pa
    Great thread. I was looking at the same pump and this sealed the deal for me.
    Jul 2003
    The Isle of Long
    Here's a good article on Vac Pumps from JB and RSES
    http://www.jbind.com/tools/userfiles...eep_Vacuum.pdf
    Also check JB's website. Very informative
    http://www.jbind.com/technical.asp
    If you get the cheaper Robinair invest in some core remover tools and Vac hoses. It helps a lot to have the least amount of restriction.
    Learning is a lifelong process
    Quote Originally Posted by gbfromsd View Post
    Heck no! I've pulled under 100 microns with oil that must have been a year old, unsealed. Once your pump heats up the moisture in the oil goes out the exhaust port. Granted, that was an overnighter . . but 92 microns, held for an hour.
    yea, it just takes alot longer with that old wet oil
    every manufacture of vacuum pump recommend changing oil after every evac. i do mine every third or fourth evac. and i chage right after evac of a burnout. you wouldn't drive your work truck for a year without changing the oil, would you???
    Apr 2009
    east coast -ish
    Even in large pull downs with large pumps 17cfm.... your vac is only as good as your oil. You will get that milky look to it the initial pull down. change the oil and the closer you get to 500 microns the clearer the oil will look when you change it. I am refering to large supermarket pull downs but the same should apply for any vac I would think.
    Wow learn something new everyday , i would have said get the bigger the better. So you can evacuate too fast?
    Quote Originally Posted by zachhvac View Post
    absolutely you can evacuate too fast!!!
    My wife mentioned that too.
    sure she didn't say bigger is better????
    I think your right , but thats not what i heard.
