Results 1 to 9 of 9
    Apr 2009
    ARI certification # missing?
    Today I went to the link someone posted earlier to the AHRI Directory and entered these two ARI #'s, but can't find them now. When I did this last week while trying to research these two configurations below, I got the certificates to come up, but the status said 'discontinued'. Does this mean anything? Should I be concerned?
    Also, can someone please tell me if these are variable speed air handlers or not?
    One last question. I see where there is a fair amount of discussion on warranty issues, but is it wise to ask if installer is bonded and insured against accidents?
    Model numbers for two RUUD systems:
    4 ton 410A refrigerant
    Downstairs: 14.5 Seer 48,000 BTU ARI #1333102
    UAPL 048JAZ condenser unit
    UGPN073AMGR gas heater 80%
    BHA32-48+X5 horizontal slab coil
    3 ton 410A refrigerant
    Upstairs: 14 Seer 35,000 BTU ARI #1283496
    UAPL306JAZ condenser unit
    UGPN05EAVER gas heater 80%
    RCFLHM3617AC upflow evaporator coil
    Those are Rudd's standard 80%gas furnaces, NOT air handlers and nope they are just standard PSC motors.
    PS. those ARI #'s still come up
    whaaaaa, you let all the smoke out
    Apr 2009
    I must have fat-fingered it, thanks. Does the fact that the model status says 'discontinued' mean anything? Should I have a part number for the air handler if I am replacing two full AC/Furnace systems?
    Part/model number of teh furnace, and of the indoor coil.
    Apr 2009
    Is the furnace, then, acting as the air handler in this config? Sorry, I am a noob.
    DC Metro Area (MD)
    Yes, the furnace has the blower.
    Apr 2009
    Is this a split-system?
    If this furnace is the air handler, then is this config a split system? And, also is the 'discontinued' status at the ARI site meaningful at all? Thanks again.
    This is a split system
    First system has Aspen coil, not sure of the status of it. The 3 ton is all Ruud equipment. I don't know what of that is discontinued. As far as I know all are current models.
    Apr 2009
    AHRIDirectory status?
    Thanks for that BaldLoonie. I didn't think those were discontinued systems. When I put in the two ARI's #1333102 and #1283496 at http://www.ahridirectory.org/ahridir...ultSearch.aspx that's where the status says 'discontinued'. Does this status here mean anything to anyone?
Tags for this Thread
