Results 1 to 13 of 18
    Kansas City Metro Area
    Crimp on connectors cooking off... hmmm...
    Due to the glorious recession I've been doing more kitchen service work.
    So I'm running into failed crimp connectors or rather failed wire at connector on steam tables and other resistance heat element controls and the element themselves.
    Other than high temp crimp connectors what other good practices need to be done or is this just the reality of kitchen equipment?
    Thanks everyone!
    Apr 2008
    Don't know if 'kitchen environment effects are an added factor -but in general all power crimps (especially replacement after overheating), is getting back to clean metal. I'll straighten the twist out and separate the strands to get a fine wire brush in there and a wipe clean, then re-twist prior to crimping.
    Winter Haven, FL
    solder the wire to the connector, takes a few mins but will help prevent call-backs. Dont forget to use ceramic wire nuts if you have to splice wires. Thanks to the recession I started working on cooking equipment. Damn, I had it easy before.
    Mar 2006
    i have a few ovens with grill tops i work on and although i don't get the High Temp Terminal ends i just get the uninsulated ones and never had a problem, also i use stainless steal nuts and bolts (if its a ring terminal)
    these grill tops are around 600 deg F
    Apr 2004
    Charlotte, NC
    Quote Originally Posted by mixsit View Post
    Second that. If you can not strip to clean, replace the wire. Nickel.
    "Fighting Ignorance since 1973 (It’s taking longer than we thought)." The Straight Dope.
    Dec 2008
    Ontario Canada-in the Banana Belt!!
    I 2nd that on the high temp nickel plate wire, and I believe there are non insulated crimp on connectors that are nickel as well and are made for high temp. I know my boss always kept a supply of them on our trucks for high temp stuff...I just liked them cuz they are nice and shiny..lol...jk
    las vegas
    had to go to the shop this pm to find some obsolete parts & found an
    un opened roll of 250 ft. # 12 high temp wire & a metal terminal box full of shiney
    terminals.. almost makes me want to do the hot side again.
    Nov 2002
    Johnstone sells a nice kit just for high temp
    If your not part of the solution, You must be part of the problem
    You need an Ideal CrimpMaster, with the non-insulated crimp jaws, also I second soldering. Fluxed, used StayBrite on the wire, crimped, fluxed and hit with a tiny bit of StayBrite. I used a Butane solder iron, since you can use them anywere. They are nice for Board repair, as they don't generate static like the AC Irons do.
    Frozen in UpState NY
    I've found most of the burnt off wires I have encountred are caused by a loose connect somewhere else in the circut.drawing high amps.
    make sure everythings tight and in good condition, if it looks iffy repair it with Hi-Temp terminations and Hi-Temp wire if it needs replacing
    End of call backs for me.
    Nov 2009
    West Yorkshire England
    Quote Originally Posted by madhat View Post
    Would that crimper be the one that crimps the uninsulated type that makes both sides roll into the middle of the wire? You know the type you see on factory made tail ends.
    The one I use is a standard ratchet crimper that has 3 sizes on the jaws and won't crimp that sort of crimp.
    I always find that the female spade connection is never tight and has to be squashed down prior to shoving it on the male spade, it lasts for a bit longer.
    Martyn
    50 & 60 hz but 100's worse
    Winter Haven, FL
    When I crimp the wires I use the inside of my linemans pliers. Its not pretty as it is flat, but the connector stays attached to the wire.
    Over the river and through the woods
    Talking
    Quote Originally Posted by Joe Harper View Post
    My all time favorite tool.....
