Results 1 to 10 of 10
Thread: Vacuum pump oil
04-16-2009, 08:46 AM #1
- Feb 2006
- 33
Vacuum pump oil
hello fellow techs I was wondering how would you guys handle your vac pump oil? at my shop they only supply us with oil from a drum and we have to put it in our own containers! I was wondering do you guys buy your own pints or gallons? and should i be concerned about moisture getting in the oil if I put it in my own container from the drum?
thanks
04-17-2009, 01:28 AM #2
04-17-2009, 11:12 AM #3
04-17-2009, 01:40 PM #4
- Aug 2006
- 2,439
How is that Container Labled? Seems like you would be in violation of US DOT and State DOT laws. Of course I'm sure you have it filed in your M.S.D.S. Booklet that you keep updated and carry in your cab at all times
04-22-2009, 10:39 AM #5
- Apr 2007
- Mesa, AZ
- 120
Relay,
I, myself, tend to believe that ALL oil is hygroscopic to some degree. Vacuum pump oil is no exception, and if you're taking from bulk containers.... as that container gets emptier it contains more air/moisture, right?? Really wouldn't be much different than just never changing the oil at all, and I know you don't allow that to happen. Just my opinion as a tech who works a lot of low-temp equip. using POE. Kevin.
04-22-2009, 08:47 PM #6
I only use the gal jugs, keep the top on tight and hope for the best.
I'm not tolerating Political Correctness anymore, from now on it's tell it like it is.
Veto Pro Pak - The best tool bag you'll ever own
04-22-2009, 08:52 PM #7
buy Gal then empty in quarts and seal tight
THE MORE I LEARN
THE MORE I FIND I DONT KNOW
Cancer Survivor
And Dam Well
Plan On Staying That Way
04-22-2009, 09:21 PM #8
you change the oil??? WOW I never -- ROFLMAO
04-23-2009, 11:45 AM #9
04-23-2009, 01:17 PM #10
- Sep 2006
- Leavenworth KS
- 259
pump oil
We buy in quarts and gallons. Pints are found around here very often. Several guys still have welch belt drive pumps, they tend to get the gallon jugs. We also send they with five gallon waste oil pails. The smaller guys only get gallon or two gallon waste pails.
The main office has a waste oil burner. We preform some of our own oil changes. Some guys send vehicles into the local quick lube others like doing it themselves. Sometimes it get's busy and they go to the quick lube also. I do really care as long as it is done.
Mike
