I am having problems with the diagnostics on a model PBKM-LD14N100F. The furnace will run through 1 or 2 cycles or until the house come up to temperature and shut off but will not recycle after that. If the cover is pull the red light indicator is on. When the lower panel is opened and replaced allowing the switch to be reset the red light goes out and the furnace goes on. It may go through 2 or 3 cycles, but then the red light goes on and it wont cycle any more until the lower panel is opened and the switch is reset. Any ideas? Is there a holding circuit that may not be working?
