Results 1 to 13 of 26
Thread: FX 40 Manual
    Jan 2005
    FX 40 Manual
    Does anyone have a pdf copy of the manual for an fx40. The little one that comes with it, with the wiring diagrams. I am trying to do mod and n2 on one and need the wiring diagram to ensure where to tie the modbus.
    Build it and it will break. Fix it and it will work. Ignore it and will cost more. Patch it and it will get worse. Cross the bridge before the flood.
    Somewhere, WI
    It won't work on a 40, you'll need a 60. 40's only have one rs485 port and is not expandable. 60's come with one but you can get an expansion card for two more.
    Jan 2005
    That is what I thought but I read somewhere about someone doing it and I was not 100% sure.
    Jan 2005
    So I am hosed there is no way to bring in a RM7800 burner interface into the jace.
    There is a second com port on the FX40, but it is RS232 not RS485. You would need a converter, but it should work.
    Or you could use a converter to go from the rs485 to IP and use the modbus tcp/ip instead of serial.
    Somewhere, WI
    Quote Originally Posted by checkvalve View Post
    I though both of them were on the same COM port?
    Quote Originally Posted by ddcfreek View Post
    Its the lower rj-45. You will have to make it. I cant remember the pinout off the top of my head.
    Mar 2009
    Several Miles from Sane
    I think checkvalve is refering to using an ethernet to rs-485 device (router ?) that get connected to the LAN (TCP/IP) and the other side goes to the RS-485 device. I have heard of them but I don't know if you can load a driver for modbus into an FX-40.
    Hoping for answer on the modbus.
    skwsproul, do you still need the pdf for the install manual ?
    email in profile if ya do.
    If sense were so common everyone would have it !
    All opinions expressed are my own. Any advice provided is based on personal experience, generally accepted fact or publicly available information. As such, it is worth exactly what you paid for it, not a penny more not a penny less !!
    Somewhere, WI
    Quote Originally Posted by freddy-b View Post
    Yes, but I thought you could only use one at a time?
    San Diego, CA
    you probably already have it
    look under C:\%Niagara_Installation_Folder%\docs\MtgWiring\JA CE-403
    Nope, I have a 485 N2 bus and modbus pluging away together on several 40's.
    Upon further review, I use lon not n2 on the 403's/40's at the buildings with modbus. Freek may be right.
    Somewhere, WI
    That's what freeks are for, right??
    They show different leds for COM1 (serial port) and COM2 (rs485 port). Looks like I am wrong...
    I may be thinking about the modems...
