Results 1 to 11 of 11
    Mar 2009
    concentric venting
    What is the advantage of a using a concentric vent thru the roof instead of running 1 pipe for the vent thru the roof and ending the intake pipe in the attic? Can the non concentric venting cause problems when it is windy or degrade the high efficiency of the condensing furnace etc.?
    May 2008
    Missouri
    The difference in air pressures (if both intake and exhaust are not in same area) can cause nuisance lock-outs with the furnace. Also troubleshooting problems if intake is not readily accessible.
    SE Michigan
    The concentric kit is one pipe that will be running through the roof.
    “Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery.”
    May 2008
    Missouri
    As I said in my earlier post, not venting both intake and pipe to the same area could cause intermitant lockouts due to different operating pressures under different weather conditions. A concentric vent runs both intake and exhaust thru a double wall pipe to the outside of the home, either thru the roof, or sidewall. Leaving the intake inside the roof (in attic), as John ask, can lead to problems.
    Mar 2009
    The reason I asked the question is because I just had a 95% Lennox installed last week. I spoke with a neighbor and discovered that his new hvac installed last fall by the same dealer was also a Lennox. The neighbor has a concentric vent installation and the pipe and flashing are black to match the roof. Mine is a white piece of PVC with aluminum flashing. These are condominiums and only 3 doors apart.
    My installation doesn't look nearly as good, and are you telling me that if won't be as efficient and or as reliable?
    Thanks for your input,
    Jun 2007
    Darby, PA
    You can paint a concentric black if needed. But it is wise to have both terminations in same area, as stated before, due to consistent pressures. A concentric is a two pipe termination, also as previously stated. This could have been worked out with installing contractor if cosmetics were a problem. A concentric is a better, more appealing termination than using a two pipe setup (meaning you would see one pipe for intake and one pipe for exhaust on the roof as opposed to a "one pipe" look provided by the concentric.) As long as PVC is sized properly and installer follwed mfr. specs, you should not have any issues.
    Psalm 51:10, 12
    It won't effect efficiency, since its still pulling outside air.
    are you sure you do not just have a white concentric vent pipe?
    color does not determine what it is.
    did you look in the attic to confirm?
    do you both have the same furnace?
    if installed by the same contractor and the same furnace, one would think they did them the same.
    Jan 2005
    Like previously stated it may be a concentric. Does it look like this?
    The pic here will be upside down for your roof application.
    "It's always controls"
    Mar 2009
    Yes, I'm sure that it is not a concentric vent pipe, it is a piece of PVC cut to match the roof angle and the other PVC pipe ends in the attic. What upsets me is that the neighbors HVAC was installed 4 months ago by the same company and his Condo is exactly like mine so there is no reason for one to be installed differently than the other.
    posting pictures may be helpful in giving a definitive answer.
    may want to call the install company and have them come out to verify proper install and ask them to explain the reasoning yours was done different.
    also, as stated prior, this may cause issues down the line and better to fix it now.
