Results 1 to 8 of 8
02-03-2012, 06:52 PM #1
- Mar 2007
- MA
- 183
Storage Pouch for Ultimate Puller
Any ideas where I can find something like a vinyl or canvas pouch big enough to fit my Ultimate puller?
I’m tired of always having to hunt around for those damn blade hooks when I need them, so would like to store it all together. I actually tried using a storage tube I made out PVC pipe and threaded caps, but it just takes up too much room in my bucket, so was thinking that maybe a flexible pouch would be a better solution.
02-03-2012, 08:03 PM #2
- Feb 2007
- Central NJ
- 366
i use a klein canvas bag, works perfectly!
http://www.amazon.com/Klein-5140-4-p...8317384&sr=8-2You have to pay your due's before you pay the rent!
02-03-2012, 09:31 PM #3
I have a small tool bag that I keep all my pullers in.
02-03-2012, 10:03 PM #4
- Aug 2006
- 2,439
Would it fit in a plastic welding rod container. Don't have to worry about ours, the other AC guy borrowed it and lost all the hooks and the hex key. I always kept them banded to the tool with a wire tie. Used the tie tension tool, so they wouldn't slip out.
02-04-2012, 10:55 AM #5
- Mar 2007
- MA
- 183
02-04-2012, 12:59 PM #6
- Feb 2007
- Central NJ
- 366
02-06-2012, 07:40 PM #7
Way back when I used to indulge in fine spirits, I would use the cloth bags royal crown came with. Had the pull string and everything.
02-06-2012, 07:59 PM #8
I store mine in a long rectangular plastic toolbox that used to hold a Dremel moto-tool. Another contractor burnt up the little drill from overuse and threw out the box. I grabbed it and customized it to hold the ultimate puller, and other related tools. I use clear zip loc bags inside to hold the fittings and attachments so they stay together if I spill the contents. It is also red so it is easy to find.
