Results 1 to 10 of 10
    Apr 2009
    Blower motor won't shut off on furnace
    Blower motor decided not to shut off during furnace operation-keeps running even after temp set point reached. Thermostat is a digital Hunter, fairly new, been working fine for a few seasons. Would not shut off when set to off at thermostat. Had to turn off at breaker box. Found a pack rat working/building on top of furnace/duct work. Could he have chewed control wires to thermostat causing this problem? How can I test various possible causes?
    Bay Area, CA
    Quote Originally Posted by hortogl View Post
    Well i would call someone who knows what they're doing and say hey can you test the various causes of my furnace not working and fix it?
    Global Warming or: None like it hot
    No pleasure, no rapture, no exquisite sin greater... than central air. -Dogma
    Nov 2008
    Colorado
    hortogl, we offer plenty of friendly advice and recommendations on this forum, but no DIY info on here.
    Questions and discussions pertaining to HVAC for the home. No pricing, no DIY, Thank You.
    Please read Site Rules Thank you.
    Thread closed.
    Mar 2009
    central illinois
    good luck.
    work to live not live to work.
    Oct 2006
    The Beach
    Call your contractor and tell him the problem. He will bring a new stat. and wire. The problem will not be hard to find. Could be a number of things that are causing the fan to keep running.
    Good Luck
    Blue Fox
    Nov 2000
    Eastern PA
    Could be a number of things for sure, but if it didn't happen before that Hunter t-stat was installed, I would make that DIY grade t-stat my primary suspect.
    Keep fixing it until you have to call a professional.
    ...seek, and ye shall find;..
    Ecclesiastes 10:2 NIV
    Oct 2006
    The Beach
    You are right Ro-Bo-Teq. My trash barrel has a lot of those Hunter states in it also some contactors that Hunter welded closed.
    Blue Fox
    Nov 2008
    Colorado
    Thread closed.
    Nobody belived you when you said closed. Guess you forgot to turn the key?
    Hmm, hate when that happens.
Tags for this Thread
