Results 1 to 7 of 7
Thread: Honeywell AX
03-31-2009, 08:38 AM #1
Honeywell AX
Ok this is frustrating. I have a station that was working great and out of nowhere some of the points started reading really strange on 1 of the xl15c controllers. I checked the points and they were configured ok but some read 32.0 f and said they were ok and 2 of them were reading like 234976.234e23 yes there was a letter in the reading. That said as I have had stations lock up and not report points before, rebooting them was the cure. So thats what I did only this time the station failed and would not restart. I then proceeded to copy the station to my machine and try to start it in the local platform, again it failed to start with a different reason. The files on it are all up to date. I have no idea what could be wrong with it if I can not get in to look at it. Any ideas.
Here is the output on the jace app director.
ESSAGE [06:44:36 31-Mar-09 EST][sys] Loading "/ffs0/niagara/stations/Mvsec/config.bog"...
ERROR [06:45:15 31-Mar-09 EST][sys] Cannot load station
javax.baja.xml.XException: Invalid LonFloat: '5.3143987552256E13' [13375:46]
at javax.baja.io.BogDecoder.err(BogDecoder.java)
at javax.baja.io.BogDecoder.decodeSimple(BogDecoder.j ava)
at javax.baja.io.BogDecoder.parseSlot(BogDecoder.java )
at javax.baja.io.BogDecoder.parseSlots(BogDecoder.jav a)
java.io.IOException: Invalid float: 5.3143987552256E13
at javax.baja.lonworks.londata.BLonFloat.decodeFromSt ring(BLonFloat.java)
at com.tridium.util.SimpleFactory.make(SimpleFactory. java)
App Failed
AND here is the local platform app director output
ERROR [07:57:01 31-Mar-09 EDT][tz database] error loading timezones.jar manifest: null
ERROR [07:57:01 31-Mar-09 EDT][sys] Cannot boot
java.lang.ExceptionInInitializerError
at javax.baja.sys.BAbsTime.<clinit>(BAbsTime.java:119 2)
at javax.baja.sys.Clock.time(Clock.java:101)
at javax.baja.sys.Clock.time(Clock.java:113)
at com.tridium.sys.resource.ResourceManager.this(Reso urceManager.java:238)
at com.tridium.sys.resource.ResourceManager.<init>(Re sourceManager.java:32)
at com.tridium.sys.Nre.boot(Nre.java:354)
at com.tridium.sys.Nre.boot(Nre.java:282)
at com.tridium.sys.Nre.main(Nre.java:93)
Caused by: java.lang.NullPointerException
at javax.baja.timezone.TimeZoneDatabase.isZoneIdSuppo rted(TimeZoneDatabase.java:232)
at javax.baja.timezone.TimeZoneDatabase.getHistorical TimeZone(TimeZoneDatabase.java:206)
at javax.baja.timezone.TimeZoneDatabase.getHistorical TimeZone(TimeZoneDatabase.java:195)
at javax.baja.timezone.BTimeZone.getTimeZone(BTimeZon e.java:63)
at javax.baja.timezone.BTimeZone.<clinit>(BTimeZone.j ava:1340)
... 8 more
Build it and it will break. Fix it and it will work. Ignore it and will cost more. Patch it and it will get worse. Cross the bridge before the flood.
03-31-2009, 09:28 AM #2
see if this relates:
http://www.niagara-central.com/ord?p...ionThread/7587
03-31-2009, 12:47 PM #3
That looks like what I need. I can not open the config.bog to edit the appropriate line. Maybe I am going at it the wrong way. Just in case how do you do it.
03-31-2009, 01:18 PM #4
This needs to be done offline, while the station is not running.
I'd copy it to your local machine via the station copier, make the changes, then copy it back.
Browse to the config.bog under MyFileSystem\sysHome\Stations\StationXYZ\ right-click and choose Text File Editor view.
scroll down to line # 13375, column #46
03-31-2009, 01:40 PM #5
Thats what I figured. I get a can not hyperlink error.
03-31-2009, 01:48 PM #6
Weird thing is I can actually go into the property sheet of the config.bog and see the entire setup.
03-31-2009, 07:47 PM #7
Got it. Could not open the text editor due to not having enough memory allocated to it. THANKS DIGO
