Page 3 of 3 FirstFirst 123
Results 27 to 31 of 31
  1. #27
    if split system get more accuracy by pump down and just running OD fan
    Good point
    THE MORE I LEARN
    THE MORE I FIND I DON’T KNOW
    Cancer Survivor
    And Dam Well
    Plan On Staying That Way
  2. #28
    Jul 2005
    How do you measure the pressure in the condenser when it's pumped down? Yesterday I checked for noncondensables by running the condenser fan, but I didn't pump the system down. (High subcooling high superheat, TXV coil.) I got a perfect match between ambient and SDT, so no noncondensables. Determined it was a restriction, like I first suspected. Then to track down the restriction I dropped subcooling at the liquid line service valve to 1 deg by reducing system charge and bypassing LP switch, then measured liquid line temp drop from the service valve to the TXV inlet. 5 deg total drop. This means that the liquid line, including the filter dryer, was using up only 6 degrees of subcooling. Not the problem. Determined that it has a bad TXV (no inlet screen). TXV to be replaced Monday.
  3. #29
    5,000 ft
    When valves are closed for pump down the service ports are open to line set and not the condenser... Am I missing something else?
  4. #30
    good tip thanks
  5. #31
    Oct 2007
    ATLANTA
    Quote Originally Posted by hvacrmedic View Post
    Hi
    Just curious do you guys typically find moisture in the system as showing a higher or lower pressure than what the proper temp and pressure relationship is supposed to be.
    Also is there a trend that certain noncondensables tend to follow which helps to identify them?
