Thread: High sulfur dioxide from drywall
03-30-2009, 01:20 PM #1
http://www.bizjournals.com/charlotte...3/daily15.html
More info on drywall off-gasing when damp.
Some fresh air ventilation and maintaining <50%RH may help this situation. Regards TBBear Rules: Keep our home <50% RH summer, controls mites/mold and very comfortable.
03-30-2009, 04:57 PM #2
There must be more to it than just SO2. SO2 is a lung irritant, but i don't see it causing major health issues in lower concentrations. We have faily high concentrations of SO2 in our milling operations (need a respirator in some areas) and the operators actually claim that once they start working there , they never get a cold again. It's keeps them cleaned out they say.
I wonder is high level of formadyhyde in cheaply made cabinets and sub-flooring or some VOC's are mostly to blame.
Fresh air ventialtion would defnitely help either way.
03-30-2009, 05:01 PM #3
Correction... I finally read the article. It's not SO2 (sulfur dioxide), that the problem, it's hydrogen disulfide (H2S) and carbonyl sulfide (COS). That's a whole different ballgame.
both are naturally occuring and commonly found in the air in very low concentrations. The most common issue it the odor. Low concetratiosn over a long time can have adverse health effects.
