Results 14 to 24 of 24
    Jun 2008
    Nasty Natty
    Thats not a call back.
    Unfortunately in the world I work in...it is indeed. What you or I may think about it perhaps is a different thing.
    Lancaster PA
    Quote Originally Posted by Sharp Snips View Post
    With the way its shown in the pics yes.
    But, by just his description. I wasn't going to lead him into thinking it should be fixed for free.
    Nov 2000
    Eastern PA
    You da man!
    I was wondering myself about your stand. Now it makes sense.
    Government is a disease...
    ...masquerading as its own cure…
    Ecclesiastes 10:2 NIV
    Lancaster PA
    Newer, kinder, gentle beenthere. LOL
    Attempting not to make brash, jumped to the wrong conclusion statements.
    Jun 2001
    Louisville, KY
    There's enough assuming in the world.
    Merry Christmas
    Nov 2000
    Eastern PA
    Quote Originally Posted by jrbenny View Post
    May we assume your mom also told you this?
    Quote Originally Posted by GREGHVACGUY View Post
    Is that a lennox furnace?
    Yes
    If so the trap on the furnace should be on the same side of the flue pipe.If its not did thay put in the kit from lennox to drain that way.
    Flue is on the same side as condensate trap
    And for the trap and drain should not be set up with the tee. Make it right and it will work better.
    T fitting is glued to the condensate trap - not sure how to take it off without ruining trap.
    Lancaster PA
    Call the contractor back.
    Jul 2001
    Run a separate line. If your drain plugs up, the condensate will back up into the coil pan and overflow into your furnace. Has your humidifier been leaking or is the white residue from an older unit?
    Quote Originally Posted by troyorr View Post
    In the past this humidifier plugged the drain hose with minerals and overflowed. That's why I'm concerned with having it plumbed properly. I'm convinced it should have a separate drain for each source of water.
    MN
    Quote Originally Posted by Travelover View Post
    yes, ideal setup would be separate 3/4" pipes for all units, but what do you think most people would say about 3- 3/4" pipes run across the floor to the drain? Most hate to have the one. But I will agree that the humidifier draining into the pipe above the a coil is going to be trouble someday, as long as they are coming back ask them to run that separate all the way to the drain, I am sure they will not have issues with that.
    You can't fix stupid
