Results 1 to 13 of 24
    Mar 2009
    Was my furnace drain plumbed right?
    I had a new high efficiency furnace installed and I'd like a second opinion on the way the drains were plumbed.
    The installer ran a 3/4" PVC pipe from the AC condenser drain to a T that drains a trickle flow humidifier to a T that hooks to the furnace condensate pump to the sump/ floor drain.
    My concern is that the humidifier creates chunks of minerals (I'm on a well system) which slew off into the drain occasionally. If those chunks block the pipe downstream of the furnace drain, it will shut down and I'll be without heat.
    Should the humidifier have it's own drain line?
    Thanks in advance for your help.
    Yes
    Chicago, IL
    As long as the PVC line has good pitch the entire way and no traps in it, you should be fine. I have never seen mineral deposits block a the drain line as long as theres pitch. However, a second drain line never hurt anyone, so as longs as there room for it, theres no problem with having two of them
    Mar 2009
    Confused
    Quote Originally Posted by craig1 View Post
    There is a very slight pitch as it works it way across the plenum, then straight down to the furnace condensate inlet, then straight down 1 foot to the floor and then nearly flat 6 feet to the sump.
    In the past the humidifier has blocked a 3/4" clear flexible tube that drained it with the old furnace setup.
    Jun 2008
    Nasty Natty
    I would say if your concerned about it, have a secondary drain pipe installed to put your mind at ease. Customer service these days should be at a premium ( it is with my company) and your concern sounds legit. They should come back and make it right. After all it's a call back, but an easy fix.
    Nov 2000
    Eastern PA
    I agree that as long as the humidifier drain is downstream from the furnace trap assembly "AND" there is a relief vent between the furnace trap assembly and the humidifier drain, there should be no problem.
    As a matter of fact, the furnace condensate is a bit acidic and just may keep the minerals from the humidifier drain from blocking up.
    ...seek, and ye shall find;..
    Ecclesiastes 10:2 NIV
    Mar 2009
    Quote Originally Posted by RoBoTeq View Post
    Actually the humidifier is upstream from the furnace condensate trap, but I like your idea about rerouting it so the furnace condensate can keep the minerals dissolved.
    Quote Originally Posted by Sharp Snips View Post
    Thats not a call back.
    Nov 2000
    Eastern PA
    Quote Originally Posted by Travelover View Post
    With the humidifier condensate being upstream from the furnace trap assembly, the pressure from the furnace blower in the humidifier drain line can adversely affect the pressure switches in the furnace. This can cause all kinds of nuisance furnace failures.
    Can you post a pic of it.
    Mar 2009
    Here are two views:
    Nov 2000
    Eastern PA
    Yea, that's not good. Pressure from the blower in the evap coil condensate line and the humidifier overflow line can wreck havoc with the pressure switches in the furnace by fluctuating pressures through the furnace condensate line. There should be some kind of air break (vent) between the furnace line and the other two lines.
    Fox Lake IL
    Is that a lennox furnace? If so the trap on the furnace should be on the same side of the flue pipe.If its not did thay put in the kit from lennox to drain that way.And for the trap and drain should not be set up with the tee. Make it right and it will work better.
