Results 1 to 13 of 17
    Filter Box Size and Furnace Cutout Size?
    If you have a 20x25 filer box and media filter butted against the side of the furnace, are you losing filter capacity if a typical furnace cutout is 15x22?
    In all of the pictures, you usually see the filter against the side of the furnace, but what's the point of a 20x25 when a 16 x 25 covers the whole cutout area? Would it be better to move the filter cabinet away from the furnace and have a metal transition piece reducing down to the furnace cutout?
    Nov 2000
    You're the first person I've seen notice this. The instructions from the filter manufacturer say that there should be a transistion of no more than 30 degrees downstream of it.
    "You do not merely want to be considered just the best of the best. You want to be considered the only ones who do what you do.".... Jerry Garcia
    "You just have to decide if you're a Tigger or an Eeyore,..I think you know where I stand on the great Tigger/Eeyore debate." Prof. Randy Pausch
    Quote Originally Posted by lbf View Post
    At 30 degrees for 4" height, then about 5" width for the transition should do it.
    Anyone know why they butt those 20x25 filters against a 15x22 cutout in the furnace? Doesn't seem to make sense.
    Because it looks nicer then this.
    Mar 2009
    Indianapolis, IN
    New member, long time lurker, first response.
    Usually the job goes to the lowest bidder or a "handy man" instead of trained, caring professionals. The customer usually don't know any better and the system is forgiving enough to get by with this type of work. Most people will either change the filter long before it is necessary (not many) or will not change it nearly often enough (most people).
    Do what is correct and sleep well at night.
    Just a thought.
    shephvac
    Quote Originally Posted by shephvac View Post
    Just a thought.
    shephvac
    Yup. People should know. I wouldn't mind paying a bit more for it, but we need to know. I asked a couple of contractors about this and they asked me why would I want a transition between the filter and furnace? I had to explain about the area of the filter, etc. Virtually everyone talks about equipment numbers, features, etc, but no one wants to review duct work in detail. I guess it doesn't pay to talk ductwork and installation when people just compare prices on pure equipment.
    The "cost less than this" in BT's drawing is the way to go.
    Seen a lot of those type installs.
    Next thing I've heard over the years. Is that the size of the opening of the furnace is X dimensions, so you don't need bigger then that from the air cleaner. So mounting it against the furnace is fine.
    Take at look at what beenthere posted and consider mounting the air filter/cleaner/purifier in the vertical drop of the return,with appeopriate transitions,then a 90 degree elbow with turning vanes int the furnace.
    Unfortunately my return is 12x20 and would require quite a bit of work to do that.
    Virtually everyone I asked if they butt the filter beside the furnace said yes. When I asked about the cutout size, they said they would build a transition, but it would be extra. I told them to put it the quote. I guess that most people look at the bottom number and it's tough for these companies to put this stuff in and lose by a few hundred. It forces them to do what everyone else seems to be doing.
    Well, at least I will have it done correctly
    Quote Originally Posted by noobs View Post
    Will the elbow have turning vanes,or a p0roperly sized inside radius?
    If not air flow will likely be uneven over the filter,which reduces the effectiness and increases the presure drop(resistance 0 thru the filter.
    Often there's not enough space to and a transition ,without moving the return drop away from the furnace.Can you post a pic of the furnace and drop?
    Here are some pictures. The return is about 13.5 inches from the furnace. There is a picture of the filterbox and supply duct. The existing furnace is narrow, only 17" wide.
    Do I have enough space?
    P.S. I bought that filtrete filter before I started reading posts here. It will be the last one
    Apr 2008
    Princeton, NJ
    Here are photos of my 20x25 filter installed in the vertical drop of the return as reference by Dash. (Before and After photos).
    Key1cc
    In the land of the blind.....the man with one eye is king....
    Nov 2000
    You have a lot of space, a good sheetmetal company would have no trouble making a nice installation.
