    Mar 2009
    mcquay water sorce heat pump
    i've been sent to work on a mcquay water source heat pump 20 ton unit. its had several compressers and a few exv valves replaced over the ten years its been installed. what i've found is that as soon as the scroll comp. starts the head pressure goes to about 200 for a second then climbs to 400 and then it shuts down due to high head pressure. the unit has excellent water flow through the coil. any help please.
    Western Wa
    Got too much gas in it?
    God Bless our Veterans
    God Bless the USA
    Metro ATL
    If you can we need to know what kind of suction pressure? How do you know you have good water flow? What kind of water temps entering and leaving are you seeing? The more info you can give us the better we can help.
