    Apr 2008
    Trane Heat Pump Question
    I had a Trane XL15i heat pump system installed. The contractor did not install a line drier. He said that the heat pump has an internal drier and a second one on the line is not needed. Is this correct? Should a drier been installed on the line? Any problems with not installing the drier on the line? Thanks for your help.
    Trane does have one built in so no additional drier is needed nor should be put in.
    Saint Augustine, Florida, United States
    10-4. Ditto. You don't want 2.
