Page 3 of 4 FirstFirst 1234 LastLast
Results 27 to 39 of 51
  1. #27
    South Shore,Long Island
    First, time is not an accurate measurement of system evacuation. Second by not using core removal tools, the size of the port has been reduced to 3/16 of an inch thereby defeating the purpose of a 1/2 inch vacuum line.
  2. #28
    Well if you watch the video I'd disagree with you in this case, it was for all intents and purposes the same setup. 6 minutes is a considerable amount of time when the only variable is the pump, this of course is my opinion and I'll be awaiting redicule because of it. Last time I checked, a recovery tank doesn't have cores anyway.
    I am the Stig
  3. #29
    Jan 2005
    Veterans Home Yaphank, NY
    RAM Teaching Tomorrows Technicians Today.
  4. #30
    Jan 2005
  5. #31
    Jan 2005
  6. #32
    Jan 2005
  7. #33
    Quote Originally Posted by addamsmasher View Post
    Now you did it you got my cousin on a roll.
  8. #34
    Jan 2005
    Now now, just edemucating the young'n
  9. #35
    thanks for the info....always appreciate the cornucopia of knowledge you offer. I take it you guys didn't watch the video. he was pulling from a recovery tank equalized with ATM. He picked an arbutrary level of 200 microns. Obviously his test was far from laboratory but I think it gave a general idea of the performance characteristics of each vacuum pump.... btw, I get paid by the hour I don't watch the clock
    I am the Stig
  10. #36
    What point of 1/2" fittings anyway? I haven't seen any equipment, new or old, with anything larger that 3/8" fittings on charge and purge type valves, and those are on BIG stuff.
    If you could pull through 1/2" fittings, then it would make a bit more sense to me. 3/8" at least, but 1/2" to 1/4" is a BIG reduction.
  11. #37
    Nov 2000
    Upstate, SC
    That I tend to agree with, but the sales rep said using the 1/2" holes with the cores removed from the 1/4" fittings does work. I will soon see because our local distributor is allowing me to use one of the pumps and the setup for 90 days. I made my own 3/8" fittings to use with my 6 cfm pump years ago and it did indeed make a difference even though I still had to connect to the smaller fittings on the equipment.
  12. #38
    I use a 3/8" hose on a brute manifold for pulling vacuum, but I also use all 3 1/4" hoses.
    My pump used to have a 1/2" port of it that I swapped out with 3/8 for that purpose.
    I don't really know that it makes a huge difference.
  13. #39
    Jan 2005
    Sorry "Grasshopper", I did watch the video and to me the time thing does not prove a thing.
    Pulling a good vacuum on a system and sweeping with nitrogen is the proper way of doing this.
    As far as 1/2" lines go, Bill Schaffer from Lennox made an excellent video showing the benifits of a larger vacuum line and the cores removed.
    Addamsmasher FYI very few Commercial Refrigeration Systems also do not have valve cores.
