    Cartersville Ga
    Trane Marine Style Water Box
    Is the marine style water box for the condenser, cast iron or steel ? I have a CVHE050FA1 S/N L92L23470 that has the division plate supports are bent allowing the plate to sit at the 11 o clock and 4 oclock position. I was hoping to weld new supports in the head in place if it is not cast.
    Dec 2008
    Dixiana, AL
    All I've ever seen are steel.
    Dec 2003
    45th Parallel
    You should be able to weld on it no problem.
    Nov 2008
    Weld in new track and install new gkts.
    Jun 2006
    midwest
    Have barstock machined to channel. Weld in new channels and install new gasket.
    Delaware
    Get a good welder and fabricate new channels as needed (do them all to get it behind you for a few more years).
