Page 1 of 6 123456 LastLast
Results 1 to 13 of 67
    Mar 2009
    What manufacturer should I use?
    I moved into a house about 6 months ago that the AC went out and it's been giving me problems. The outside unit is a goodman, which is only about 3 years, but it's not under warranty.
    I've been reading a lot of complaints about goodman, but just saw the JDpower ratings that gave goodman a good rating. The problem is that I don't know much about goodman, but from reading a lot of bad posts about goodman and then having my system outside go out that's only 3 years old just doesn't give me much trust.
    Is there another brand that gives you the best bang for your buck? One contractor was telling me to go with rheem instead of goodman. Another contractor that was charging so much more recommended american standard and was telling me that it's trane branded.
    I prefer to have less of a warranty and more of a reliable system even if it costs me more. So I was just looking for inputs and I couldn't find any other reports except the one from JD power. Consumer reports didn't seem to have any ratings either.
    SE Michigan
    If its only 3 years old, it should still be under warranty. Atleast 5 years parts and 10 on the compressor.
    What makes you think that its not?
    "If anybody can draw on the power, where do we put the meter?" - JP Morgan before pulling Tesla funding
    Dec 2006
    Middle Tennessee
    Quote Originally Posted by coolwhip View Post
    the person who installed it was probably unlicensed, so therefore it is not under warranty
    also the system was probably installed in an unproffessional manner
    this MUST be Goodman's fault
    Jun 2007
    The Twilight Zone
    You can still select Goodman. Warranties are excellent. Just make sure that it is professionally installed.
    Mar 2009
    So most of you recommend that I go with a goodman then? My other question is that a friend was telling me that he thinks the problem with my outside unit is that the roof is slooping down and that I should put a gutter near my outside unit, because he said too much water is pouring on the unit and it's causing the corrosion and problems with the unit.
    I'm starting to lean towards the goodman if most people do think that it's a good unit. What is the deal with the tax credit? is it 30% of the cost of the installing and doing everything?
    Lancaster PA
    Ok.
    So what brand is the indoor unit(air handler, evap coil if you have a furnace).
    If mismatched. That may have something to do with the outdoor unit having problems.
    There several things that can cause the outdoor unit to fail. That are far beyond the control of any manufacturer.
    Are the contractors that are giving you estimates, replacing the entire system, or just the outdoor unit.
    Mar 2009
    The inside unit/air handler is a carrier, which is about 12 years old. The inside unit has problems leak and other problems. The outside unit is only 3-4 years old and it's a goodman. I was told that the inside unit is 10 seers, while the outside one is 13 seers if I'm not mistaken.
    All the quotes have been to replace both together.
    Thanks in advance
    Mar 2009
    I don't have any of the original paper work with it and the paper that was on the side of it has been ripped off. I'm told that if it was purchased online there's no warranty and also read other things that it's only a warranty if it's installed with the same inside airhandler unit, but not sure about that.
    Lancaster PA
    The mismatch and leaks of the indoor unit, are more to blame for your outdoor units failure, then the brand name on it.
    A good contractor that installs a matching system. Will provide you with a more reliable system. Then just buying a brand name.
    Did you get a second opinion on what is wrong with the outdoor unit.
    SE Michigan
    Quote Originally Posted by boneac View Post
    Gotcha.
    My advice is to go with a licensed and insured company that will perform a manual J load calculation to size the A/C properly.
    Have the company pull a permit so the install can be inspected by the city (this helps eliminate hack installs).
    Choose a brand that offers a competitive warranty, go with a R-410 system (Freon) and not R-22. Have a matching cased evaporator coil as well as lineset, electrical whip and disconnect installed.
    Don'T forget to register your product...either online, or snail mail.
    Mar 2009
    Well I found out the outside unit and inside unit is 10 seers, so if the inside needs replaced then that's the reason that the outside is being replaced.
    I was looking at this table below and it seems that there's a lot of savings with a 13 seers, but the 14 or 15 I'm not sure it's worth the money as I'm told it's about 750 bucks more per seer give or take.
    http://www.yorkupg.com/homeowners/ai...=1&ProdID=0%20
    I was told that a rheem would cost about 750 more dollars and that a Trane would cost 1,500 more than the goodman.
    I'm guessing the trane isn't worth the money?
    SE Michigan
    No pricing questions!
    Nov 2008
    Colorado
    Quote Originally Posted by Airmechanical View Post
    In a way, it is their fault, because they market their equipment directly to the homeowners. JMO
