Thread: Vent Proximity to Bedroom Window
03-20-2009, 02:20 AM #1
New Guest
- Mar 2009
- 1
Hi there folks, I have a quandary: My HVAC installer is determined to install a horizontal pvc vent/intake about 3 - 4 feet from a bedroom window because it is an otherwise ideal location due to the way the floor joists run and some other structural constraints like a nearby brick fireplace. This bedroom is a desirable bedroom for my forthcoming "bun in the oven", but the idea of any fumes leaking back in at all will absolutely count that room out. I don't know if I can ever fully trust the room with an exhaust pipe so close.
So I have a few questions:
- In your experience, have you noticed any appreciable seepage of exhaust back in to the house with a reasonably well (and new) sealed window?
- How long can a pvc exhaust pipe be? I may want to route the pipe the long way to the side of my house, but there will be a few bends to get it done. In total the length would need to be about 20 feet.
- From what I can tell, code says 12" clearance from the window and 12" above the ground. I feel like this implies that HEFs have relatively safe/clean exhaust. Is this true?
I expect the prevailing easterly breeze to dispurse the exhaust plume pretty quick, but I just can't get over an exhaust pipe termination so close to living/sleeping quarters.
I'd love your thoughts and opinions
03-20-2009, 05:35 AM #2
Its not a problem on average construction homes.
If the window leaked like a sieve, it could be.
As far as length, varies with brand and size of furnace.
03-20-2009, 09:16 AM #3
In the winter most people will sit in a idling car with an exhaust pipe within 3 feet of a window.
I don't blame you for having concerns. Ask the installer if it's possible to terminate it on another wall or further from the window.
03-23-2009, 08:35 PM #4
i agree with the car exhaust analogy, the gases from the furnace are a lot cleaner than from a car and will disperse fairly quickly in the atmosphere. If your window is relatively new and in good repair then you should have no worries.
03-23-2009, 08:54 PM #5
we have been installing 90% furnaces for many years, as long as the install instructions are followed you will not have any problems with 3-4' to a window.
depending on the install many of them are as close as 1' and no problems.
