Voters
144. You may not vote on this poll
  • june 12
    36 25.00%
  • june 20
    33 22.92%
  • july 1
    27 18.75%
  • july 12
    48 33.33%
Page 96 of 2476 FirstFirst ... 468689909192939495969798991001011021031061461965961096 ... LastLast
Results 1,236 to 1,248 of 32179
  1. #1236
    Wouldn't a probe type thermometer on that fluke get a more accurate reading? I think that a clamp might be tough to get on the sphincter line.
  2. #1237
    wat up heavy?
    I seem to be making friends every where!
    I am liked even better thaan robotek!
    richard weed
    Quote Originally Posted by heavymetaldad View Post
    hey dick! how's the weed?
    true knowledge exists in knowing that you know nothing.
  3. #1238
    Outside The Motor City
    Quote Originally Posted by Busadad View Post
    Is a fart a superheated gas or a superheated vapor ?
    SATURATED VAPOR!
    Peace Brother!!!!
  4. #1239
    And remember to change the filter dryer (under ware) often
  5. #1240
    yes you are correct!
    I was thinking of the peenis line.
  6. #1241
    yes but you must use an alumina, silca zeolite type of aDsorbant drier such as depends!
  7. #1242
    And Tum to neutralize the acids
  8. #1243
    NC Coast
    Quote Originally Posted by supertek65 View Post
    well, assuming that the saturated flagellant temperature is 98.6 degrees Fahrenheit, One would accurately measure the sphincter line temperature preferably using a quality meter such as the fluke 52 with clamp on type k thermocouple or any equivalent rtd temperature indicator .
    simply subtract the saturated flagellant temperature from the sphincter temperature for example;
    leaving sphincter temperature 106.8 degrees f
    saturated flagellant temperature 98.6 degrees f
    actual superheat 20 degrees f
    [/QUOTE]
    Uh.... DUDE! Check your math Dr STdickweed!! try 9.2
    And..... to answer your question......
    ONCOLOGIST :.......... The profession of studying the direct relationship of a service technician in the HVAC industry and the amount of calls received in overtime hrs. Also the quality of service in said hrs.
    Pronounced.... ON CALL Ogist! DUH!
    LOL
  9. #1244
    Hey budz hope you had a good day
  10. #1245
    Mar 2009
    Missouri
    Bubblehead, that was good. "ON CALL Ogist! DUH!"
  11. #1246
    Night all
  12. #1247
    Apr 2009
    Owsego, IL (Chicago)
    waiting for that definition in Wikpedia !
    LMFAO like 3 times
    way to funny Bubble
  13. #1248
    NC Coast
    Sup Homey! Hope You had a good day FCS!
    Mine started off..... ok I guess.... Accumulator change out on a stand 10 ft in the air with about 1 ft of room on one side of the stand. Took me 4.5 hrs (also had to changeout condenser fan motor and blade (rusted together) Capacitor and contactor. That went ok (cept wore me out up and down up and down like you in the bed! LOL)
    Then went to do a 2 system maintenance at 2:30 (suppose to work the mart at 6pm ) thought I would be done about 5pm..... till the Bomb!
    Imagine this..... And no I do not know the solution... (yet). Ran system in cooling. pressures about 53/160 (R22 carrier system v/s ahu) I had a 20-22 sub cool. Looks overcharged right? (about 69 in house and about 63 outside) I had a 30 degree TD!!! again... possibly overcharged right? Seems the fan isnt ramping up. trouble shot the module and motor. (one step says if you have -12vdc going to the motor and when jumpered, fan doesnt run... motor or module bad!) well warranty system... SO I replace the whole motor module assembly. still looks screwy. its late so I place it in heat.... had about 40/210 at 55 degrees outside. Looks undercharged right? Only had a 20 Temp rise. Said screw it... we will come back when you come back in 2 weeks, (they leave sunday back to VA.) Something is not right.... but I dont know if its bad indoor TXV flooding the coil (hot rag increased pressure ) or if somehow the motor circuit bd controls the ramp. Idnt think it does... I think the module controls the ramp.... and the tshooting guide said motor/module. I am lost. Spent 6 hrs there... .and couldnt work the mart!
    Any suggies FCS? Come on you da MAN!
    Bubz
