Voters
130. You may not vote on this poll
  • june 12
    33 25.38%
  • june 20
    31 23.85%
  • july 1
    26 20.00%
  • july 12
    40 30.77%
  1. #24701
    Head looks about normal for that kind of ambient.
    A piston MD might run a higher SC than a TEV unit.
    Given that and ASSUMING that the airflow was correct, I'd shoot a bit of gas in it and see what happened.
    I was thinking airflow
    But like I said I been out laid up for a good while. Going to go out at 5:30 am with his young son (mid 20s )
    see how I do.
    THE MORE I LEARN
    THE MORE I FIND I DON’T KNOW
    Cancer Survivor
    And Dam Well
    Plan On Staying That Way
  2. #24702
    Quote Originally Posted by fcs
    see how I do.
    Low airflow would tend to give you a lower Superheat.
    High airflow would show up with high suction and high Superheat.
  3. #24703
    Can tell I've been NOT doing Any thing to keep my skills for the last 2 years.
    THE MORE I LEARN
    Cancer Survivor
    And Dam Well
  4. #24704
    Another thought that occurs to me would be a restricted piston or bad TXV.
    Nothing wrong with being rusty. 2 years is a long time.
  5. #24705
    Fuquay Varina, N.C.
    The numbers you gave are missing one very important piece of information, what was indoor wet bulb temp? with that you could determine what the target S/H should be.
    I agree that it probably is a little low on charge, if nothing has been done to it in the nine years I would first check that Coil is clean, blower wheel is clean and then recharge unit, probably a piston metering system so S/H is the important number.
    Good luck and glad to see you are getting to work on a unit, be careful and do not hurt yourself.
    RSES Member.
    Mainstream Engineering Certified.
    HVAC/R PM Technician.
    410A, & GREEN HVAC/R Technician.
    NATE Core.
    Working not as to please men but to the Glory of Christ my KING.
  6. #24706
    Southeastern Pa
    With 10 SC, you have liquid available at the metering device, so your SH should be lower. I'd expect a restriction before the evap, like a clogged dryer, orifice, or a closed txv.
    Good morning, Bret and everyone.
  7. #24707
    Vancouver Island, B.C.
    IF it's short on charge.....you should be running "0" SC...
    "The quality you deserve is not expensive---it's priceless"
  8. #24708
    Feb 2012
    GTA, ON
    'Morning Bret and everyone.
  9. #24709
    fix more later sick and weak night
    THE MORE I LEARN
    Cancer Survivor
    And Dam Well
  10. #24710
    Southeastern Pa
    Good morning, Bret and everyone!
    Stay safe.
  11. #24711
    Fuquay Varina, N.C.
    Good Morning Bret and Everyone, Happy Independence Day, Stay safe and enjoy.
    RSES Member.
    NATE Core.
  12. #24712
    Feb 2012
    GTA, ON
    'Mornin Bret and everyone.. Time to throw some dead animal flesh on hot iron Happy ID!
  13. #24713
    happy 4th all
    better today rest up and family time Will post about unit later
    THE MORE I LEARN
    Cancer Survivor
    And Dam Well
Page 1901 of 2131 FirstFirst ... 9011401180118511891189418951896189718981899190019011902190319041905190619071908191119512001 ... LastLast
