Voters
144. You may not vote on this poll
  • june 12
    36 25.00%
  • june 20
    33 22.92%
  • july 1
    27 18.75%
  • july 12
    48 33.33%
  1. #23843
    Vancouver Island, B.C.
    Got to play with a neat thing today.
    It's being called a "Non-compression cascade system"
    Basically, a thermosyphon.
    The rack system runs a plate heat exchanger. In the secondary side, there is refrigerant that is condensed by the plate HX, separated through a phase separator. The liquid runs down into the coils (no metering device), boils off.
    The vapor rises back up, through the phase separator and back into the plate HX.
    All flow in the secondary is natural. No pumps or other means to move fluid.
    All in all, a pain in the A$$ because you have to add a little gas and wait for it to react. Slow, painful and tedious, but there are 2 of them running happily away after today.
    Sounds similar to the old KeepRite Q-pipe system...
    "The quality you deserve is not expensive---it's priceless"
  2. #23844
    Quote Originally Posted by Doug Lockhart View Post
    Never seen one, nor have I heard of it.
    I DID, however, discover that the 1200 does just as AWESOME of a job measuring approach temperature as it does measuring superheat.
  3. #23845
    What refrigerant did they use?
    Here's the heat pipe....basically individual pipes part filled with refrigerant and the outgoing heat boils it and it ascends up the tilted pipe to the cold air stream which condenses and it runs back down to the the 'hot' side....again
    http://www.industrialair.com.au/docu...a_brochure.pdf
  4. #23846
    In this case, 404a on both sides of the system.
    The biggest pain is charging it. There is not a good and clear-cut method for determining the charge for the secondary side.
    They call it "trial and observation"
    I call it "gas it and guess"
  5. #23847
    Now that I read through that, I have seen a heat pipe, once.
    I have no idea if it was working or not as I had no real idea what I was actually looking at nor did I have any real idea of how to test it.
  6. #23848
    Delta Ts only across each coil
  7. #23849
    SUHWEEEEEEEEEEEEEEEEEEEEEEEEET!!!!!!!!!!!!!!!!!!!! !
    true knowledge exists in knowing that you know nothing.
  9. #23851
    Quote Originally Posted by supertek65 View Post
    was think the same thing.
    But it's much more fun when you don't have a customer looking at you wanting it up ASAP and also getting ready to b!tch about the bill
  10. #23852
    busy 2 days
  11. #23853
    busy 2 days
    You and Karen been in bed for 2 days with a case of whipped cream, a 20 litre can of mazola oil and matching bowling balls....?
    You dirty pig you??!!!!
  12. #23854
    I've got a dirty, dirty mind, but I just cannot think of anything you would do in bed with whipped cream.
  13. #23855
    Southeastern Pa
    Good morning, Bret and everyone!
    Just what I needed to start off...thoughts about my whipped cream days......
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
Page 1835 of 2473 FirstFirst ... 83513351735178518251828182918301831183218331834183518361837183818391840184118421845188519352335 ... LastLast
