Voters
143. You may not vote on this poll
  • june 12
    35 24.48%
  • june 20
    32 22.38%
  • july 1
    27 18.88%
  • july 12
    49 34.27%
  1. #2055
    is that you time builder??????????????
    true knowledge exists in knowing that you know nothing.
  2. #2056
    have a good night ST
  3. #2057
  4. #2058
    good night fcs
  5. #2059
    No but I think that his wife
  6. #2060
    windy city
    Ya post post picture would be great. Glad to hear your busy.
    okie dokey!!!!!!!!!!
    plant supplies chilled water (chw) 24/7/365 for space conditioning. entire building load is cooled by plant including server rooms. system is a 3 pressure r-22 liquid overfeed system with a guesstimated charge of 175,000# of r22. primary cooling is provided by spinning up to (4) 500 hp screws to freeze water, 800,000# of ice. heat transfer of 'ice' to secondary chw thru plate frame exchangers. the colder it is, the longer the ice lasts. 3 days max.
    as the ambient increases, ice is made nitely. as temp increases and building needs comfort cooling (it's a huge glass box), (2) 700 ton centrifugals cooling the primary chw loop to precool the building secondary thru plate frames chw before sec. chw. 'hits' the ice plate frames. usually supply 42 or lower chw to bldg
    when needs dictate, when the above isn't enough, all of the above is kept on line AND (thru valving) the 22 system is put into a giant 'dx' system.
    main air handlers (7) are 140,000 cfm w/ 400 hp s/a and 200 hp r/a motors. the s/a motors are double shafted, all with pneumatic controlled vanes.
    heating is provided with (5) 300 HP water tube HW boilers, suppling the bldg. with 3 different temp. zones. heat can also be provided with hot reefer gas.
    bldg. is pneumatically controlled, (6) 40 hp quincy recips.
    iffen i left ennything out, ASK!!!!!!!!!!!!!!
  7. #2061
    windy city
    screw compressor room
  8. #2062
    windy city
    plate frames
  9. #2063
    windy city
    evaporative condensers
  10. #2064
    windy city
    asccumulator 1 - 15' long, 8 ft dia
  11. #2065
    windy city
    accumulator 2 same as 1 except for internal baffles
  12. #2066
    windy city
    accuminlator 3 - 30' long, 10' dia
  13. #2067
    windy city
    reefer pumps under ac-1
Page 159 of 2489 FirstFirst ... 591091491521531541551561571581591601611621631641651661692092596591159 ... LastLast
