Voters
144. You may not vote on this poll
  • june 12
    36 25.00%
  • june 20
    33 22.92%
  • july 1
    27 18.75%
  • july 12
    48 33.33%
  1. #18370
    windy city
    if it's wrong..............................
    \m/
    original member of the racoon brotherhood
  2. #18371
    i just hope if it is backwards it does not come apart?????????????
    true knowledge exists in knowing that you know nothing.
  3. #18372
    windy city
    Quote Originally Posted by supertek65 View Post
    BOB
    i hope you are being serious?????
    this thing is on a pump!!!!!!!!!!!!!!!!
    as serious as a heart attack.....................
    \m/
  4. #18373
    good point!!!!!!!!!!!!!!!!
    Quote Originally Posted by heavymetaldad View Post
    if it's wrong................it's the factory's error...............
  5. #18374
    windy city
    is it together?
    \m/
  6. #18375
    windy city
    see avatar above left hand corner...........
    \m/
  7. #18376
    windy city
    bbl..........
    \m/
  8. #18377
    Southeastern Pa
    Wait a minute.
    Does this thing use both fans, one a CCW fan from the end you showed, and another CW fan on the other end?
    In that case it will pull stuff through the machine, from one end to the other.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
  9. #18378
    good question????????????????????
    Quote Originally Posted by timebuilder View Post
    Wait a minute.
  10. #18379
    it is almost done!!!!!!!!!!!!!!
    it would take about 160 man hours to get to the fans
    like you said choo choo put them on and balanced them
    is it together?
  11. #18380
    i know this is all confusing
    ART
    this is a double hung motor
    where the fans are in the crankcase
    would be directly behind the sleeve bearings
    this would be in about 16" hg
    this area would directly behind the impeller and I would think???? hey should pull out of the center of the stator>??
    then it would find its way between the motor housing and stator and fet sucked into the evaporator
    all i know is
    in the drawing what they have cw is ccw and so on
  12. #18381
    dick!!!!!!!!!!!
  13. #18382
    Northern Va
    Wait a minute.
    now i only do residential BUT this sounds correct.....
Page 1414 of 2471 FirstFirst ... 41491413141364140414071408140914101411141214131414141514161417141814191420142114241464151419142414 ... LastLast
