Voters
143. You may not vote on this poll
  • june 12
    35 24.48%
  • june 20
    33 23.08%
  • july 1
    27 18.88%
  • july 12
    48 33.57%
  1. #18357
    Southeastern Pa
    Quote Originally Posted by supertek65 View Post
    i guess all i had to ask??
    what if that pic was turning CW???????????
    If the shaft in the pic is turning CW, then the flow will be AWAY from the armature, but I don't understand why the airfoil design faces the wrong direction compared to the airflow over a wing.
    Unless they are doing that to help reduce cavitation....
    I'd have to read something about that fan to really know, but yes, CW in the pic WILL pull from the armature toward the shaft end.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
  2. #18358
    that is what i thought!!!!!!!!!!!!!!!!!!!!!!!!!
    the new fan is on the other way!!!!!!!!!!!!!!!!!!!!
    so it was wrong for 45 years?????????????????
    Quote Originally Posted by heavymetaldad View Post
    and the shaft spins ccw in your pic? it's in backwards
    true knowledge exists in knowing that you know nothing.
  3. #18359
    windy city
    i have 3 pages open here..........
    \m/
    original member of the racoon brotherhood
  4. #18360
    windy city
    could be.................found a yt oil reservoir drain installed upside down,,,,,,,,,,,,,
    \m/
  5. #18361
    ART!!!!!!!!!!!!!!!!!!!!
    i know a little i say little about air foils
    so i agree, i think the original fans which you see here are on wrong!
    that being said!!!!!!!!!!!!!!!!!!!!
    did trane put the airfoil on the wrong side????????????
    Quote Originally Posted by timebuilder View Post
  6. #18362
    windy city
    i'm confused............... if it spins ccw, and the fan is supposed to direct refrigerant into the motor, installation is correct.
    they used vapor to cool the stator? usually they inject liqwid
    \m/
  7. #18363
    windy city
    darn 30 sec. rule here...............and the slow refresh
    \m/
  8. #18364
    I hate making decisions that go against what i pulled out!!!!!!!!!!!!!!!!!!!!!!!
    anyhow that fan is now on the other side spinning CW and hopefully pulling cool liquid out of the evaporator
    but airfoil seems wrong??????????
  9. #18365
    windy city
    time to get clean.................lemme know what you figger out
    \m/
  10. #18366
    Southeastern Pa
    From looking at the parts list on page two of the pdf, it looks like one fan goes on the far end for CW, and one goes on the near end for CCW.
    Which way does your shaft turn? CCW as shown in your picture?
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
  11. #18367
    windy city
    it'll be fine...............those old machines could take a beating and still make water cold
    \m/
  12. #18368
    that pic i posted goes ccw that is how it came off
    if you look at the pdf it says CW
  13. #18369
    BOB
    i hope you are being serious?????
    this thing is on a pump!!!!!!!!!!!!!!!!
Page 1413 of 2471 FirstFirst ... 41391313131363140314061407140814091410141114121413141414151416141714181419142014231463151319132413 ... LastLast
