Voters
144. You may not vote on this poll
  • june 12
    36 25.00%
  • june 20
    33 22.92%
  • july 1
    27 18.75%
  • july 12
    48 33.33%
  1. #18344
    windy city
    Quote Originally Posted by timebuilder View Post
    Well, I've already offered to take him to The Majestic for smoked tenderloin sandwiches.
    I've been trying to get Frank to hook me up with a job working for his comapny in KC. ....
    well, they do chillers............... the ones down the hall next to the coffee machine................
    \m/
    original member of the racoon brotherhood
  2. #18345
    i am confused
    i thought they were supposed to pull out!!!!!!!!!!!!!!
    if they suck IN
    they would be fighting eachother????????????
    true knowledge exists in knowing that you know nothing.
  3. #18346
    i do work on fractional hp chillers
    Quote Originally Posted by heavymetaldad View Post
  4. #18347
    Southeastern Pa
    So, you are saying that they took the fan marked as 25a in the doc, which is mounted that same way in the pic you posted, and put it on the other end of the shaft, turned around, so that the same chamfered side of the hub fits up against the armature?
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
  5. #18348
    Southeastern Pa
    Quote Originally Posted by supertek65 View Post
    i am confused
    if they suck IN
    In the pic you posted, that fan will pull whatever is surrounding it in towards the armature, if the shaft end you are showing turns CCW.
    Thats the same end with call out number 26 on it in the diagram, right?
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
  6. #18349
    windy city
    dammit bob
    this fan
    it is turning CCW
    is it pullin out
    or
    pushin in??
    this job is done.
    but this is how the cooling fans were when i took it apart
    when trane sent it back that fan was on the other side
    it is liquid cooled and the fan should pull from the inside
    i believe the original fan was on the wrong side, or ofcourse they both were??
    this side turns CCW but i think that is a CW blade
    i do not know the internals of that machine, what does the fan do? push gas into the stator? or pull it out?
    \m/
  7. #18350
    no the picture i posted is 25B, but does go CCW
    now that i got the rotor back
    that fan is on the other side going CW
    just like you are looking at it but CW
  8. #18351
    i understand that it should pull from those motor cooling flanges that you see in pdf and pull out across the stator
  9. #18352
    dr houston!
    am i fu^*%$^*$ED??????
  10. #18353
    i guess all i had to ask??
    what if that pic was turning CW???????????
  11. #18354
    Southeastern Pa
    Geez, we almost need "go to meeting" here.
    Okay.
    The fan marked 25a is now on the other end, turned around so the same edge of the fan hub is closest to the armature, and THAT end (the 25b end) is turning CCW?
    That fan will pull towards the armature.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
  12. #18355
    windy city
    and the shaft spins ccw in your pic? it's in backwards
    \m/
  13. #18356
    windy city
    nope..............i'm wrong.that prop will draw across the rotor thru the stator when spinning ccw
    \m/
Page 1412 of 2474 FirstFirst ... 41291213121362140214051406140714081409141014111412141314141415141614171418141914221462151219122412 ... LastLast
