Voters
143. You may not vote on this poll
  • june 12
    35 24.48%
  • june 20
    32 22.38%
  • july 1
    27 18.88%
  • july 12
    49 34.27%
  1. #15757
    michigan
    Good morning all, been a while since Ive been here. I have continued to keep up with this thread, just not chimed in. Life got busy and just havent taken the time to stop by. Bret I salute you for leaving that butthole of a company and I am confident things will work out for you!!!!
    Bob, that looks like one hell of a mess.................good luck wiht that abicus
  2. #15758
    Southeastern Pa
    Quote Originally Posted by heavymetaldad View Post
    Morning JP.
    Machine hasn't run in 3 years due to manufacturing problems. Machine is a heat recovery, so, it is able to run all year round. It's for comfort cooling/heating. Yes, it has back up.
    And, I can't understand, plaese try to explain this. It can produce about 110,115 degree water, which is enough to heat in chicago, where design is 0. They have back up electric water heaters. Electric heaters are more costly to use, from what I've been told. Elecrtric water heaters are more efficient, I would think, being able to get 100% out of it, where spinning a machine that uses energy to compress freon, and then heat transfer to water, AND those motors were designed in the 40's, which makes them energy hogs,. somehow my abacus doen't carry over enough decimal points to make sense.
    If I had to guess (and I guess I am volunteering to guess) the difference is that using electric heat creates the heat from electricity (from "zero to BTUs") and the machine is used to MOVE the EXISTING heat (BTUs there to BTUs here) rather than create the heat.
    Make sense?
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
  3. #15759
    alright tigger
    ill see ya soon!!!!!!!!!!!!!!!!!!!!!!
    Hey guys, my last day is Thursday I start my new job in Kansas on Monday so I'm going to spend a couple days at the lake and river enjoying the peace and serenity of the county. I don't have a house yet so I won't be around for awhile untill I get settled in. Well take care everyone and Frank I'll give you a shout when I get around K.C.
    true knowledge exists in knowing that you know nothing.
  4. #15760
    Vancouver Island, B.C.
    Quote Originally Posted by timebuilder View Post
    Make sense?
    That'd be a heat pump....first law of thermodynamics.....
    "The quality you deserve is not expensive---it's priceless"
  5. #15761
    hey duuuuuuuuuuuuuuug
  6. #15762
    Southeastern Pa
    Quote Originally Posted by Doug Lockhart View Post
    Correct. Cheaper to move heat than to make it.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
  7. #15763
    The first law of thermodynamics, an expression of the principle of conservation of energy, states that energy can be transformed (changed from one form to another), but cannot be created or destroyed.
  8. #15764
    We were granted the position in designing the GeoExchange System and directing the Mech Eng. on the Brentwood College School's new Dining Hall here at home. We had built the first 'Ocean Coupled' system about 8 years before and with this building we got them to put in a 40' X 4'W X 8'D gray water heat recovery pit. We then connected that to 6 heat pumps that are our own design that heat domestic hot water up to 170 degF. It is the the first of their kind and we used 404a scrolls running on another refrigerant.
    We only have one problem....we are recycling TOO much heat. We have to dump to the building loop/campus loop/ocean loop probably twice a day.....
    The building should save approx. $150,000/yr in energy and pay for the $1M ocean loop infrastructure in 5-6 years....
    MOVE IT DON'T BURN IT!!!
  9. #15765
    hey dug,
    we want to rebuild some old mcquay splits that are up on a tall roof and sorta built into the building
    i wanted to use the frame and put in new condenser coils, evaporator coils ,
    eev, scrolls and such
    the only thing is we would need to get it a seer rating for leed points!!!!!!!!
    how do we do that????
    if anybody would know? you would!!!
    frank
  10. #15766
    hey dug,
    frank
  11. #15767
    Southeastern Pa
    I knew that Doug and I had things we could agree on.
    Pretty cool, pulling heat out of the ocean. Neat!
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
  12. #15768
    hey that is cool!
    two exact same posts!
  13. #15769
    hey dug!
    while i got you
    is british columbia like a state???
    what is the difference between a province and a territory?
Page 1213 of 2489 FirstFirst ... 21371311131163120312061207120812091210121112121213121412151216121712181219122012231263131317132213 ... LastLast
