Voters
143. You may not vote on this poll
  • june 12
    35 24.48%
  • june 20
    32 22.38%
  • july 1
    27 18.88%
  • july 12
    49 34.27%
  1. #15432
    good morning AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAART!
    true knowledge exists in knowing that you know nothing.
  2. #15433
    Quote Originally Posted by supertek65 View Post
    hey JJJJJJJJJJJJJJP!
    Ray,
    yeah, there are air cooled compressors, refrigerant cooled compressors,
    screws, scrolls, tin can, semi hermetic, rotary, centrifugals and such!
    each type of compressor can tolerate more liquid than another.
    if you look at a refrigerant cooled copeland semi, the refrigerant must go through the end bell of the compressor which is a really cool, like neet! manifold which by itself will eliminate liquid, and then go over the entire motor, which if low on refrigerant? will be hot! that should flash off any remaining liquid! and then into the suction valve!!!! While i have seen these oil slugged a million times!! with broken connecting rods!
    I have rarely seen one liquid slugged!
    I personally HAVE liquid slugged a small compressor a long time ago!
    it goes- KLUNK KLUNK BZZZT!
    on the other hand a copeland air cooled semi like an LALA in a small referigeration application the liquid refrigerant would go directly into the suction valve!!!!
    I CAN'T believe that you would actually admit something like that, Frank.
    I know that I would never admit to having personally liquid slugged a Copeland 'K' body compressor while working on a small, R-12 door cooler about 13 years ago. NEVER!
  3. #15434
    hey Ray
    glad the apertment is holding up well!!!!!!!!!!!1
    glad school is goin well!!!
    you will enjoy pshchRometrics!!
    it is fun! pay a lot of attention as it will serve you well in the field!!
    so will learning the PH chart
    learning to read a psych chart is good!
    learning to use the process line to determine your sensible load and latent load is the best part!!!!
    have fun
    frank
    there is a great pdf on this site!
    in the educational section, i downloaded it!!!!
    Quote Originally Posted by RayD8630 View Post
    Hey Frank.
    The apartments holding up. School goes okay. We started the last unit Friday- Air Conditioning and Psychometrics. After that we have to finish off electrical and then we spend the days in the shop doing our projects. I write my Ozone Depleting Substances card on Wednesday the 31st. I got a copy of An Inconvenient Truth, and the CFC manual that I'm going to go over a few times in the next week to get that card.
    Thanks for the info. They've taught us to liquid charge but if you need to top off, vapour charge. When it comes to blends I was told to let it flash off in the manifold after you've taken it out of the tank as a liquid. As far as the low pressure switch we were told to put jumpers across it to by-pass it.
  4. #15435
    Did I said that was me?????
    surely it was my apprentice and I was there to witness it!!
  5. #15436
    you mean hypothetically speaking! right?
  6. #15437
    I don't feel too awful bad about it. I was the apprentice back then.
    It taught me something, as have all the mistakes and missteps that I have made along the way.
    Making a mistake isn't the problem. Not LEARNING from that mistake is.
    That is the lesson that I try to hammer home to every noob that I talk to.
    You WILL screw up. It isn't a matter of IF, but WHEN.
    What is most important is what you LEARN from it.
  7. #15438
    i would never ever admit to filling a 1,250 ton chiller on the condenser loop and leaving the small 3/4" vent open, and spraying water all over the 4600 volt/ 2,500 amp switch gear and the explosion blowing the doors off the panel!!
    hypothetically speaking! that would suck!
  8. #15439
  9. #15440
    good point!!!1
    i do not feel so bad because!
    22 years ago my official training went like this!
    1. ride with this guy for a day, he is really smart! "beer can cold and sweating "
    2. ride with this guy for a day he is really smart! "ambient plus 30"
    3. DAY 3! do you feel like you are good enough to do this on your own? "YES"
    4. DAY 4! after lunch, here is your truck! go get the parts you need! WHAT PARTS???
    5. sell a lot of new air conditioners! because I do not know how to troubleshoot them!
    6 go to alot of RSES meetings, buy alot of books,
    7 spend literally thousands of hours reading formentioned books!!
    8. ask as many questions as i can!
    9. read lots of books!
  10. #15441
    arc flash
  11. #15442
    good point!!!1
    Sounds a bit like the training that I got. Lots of 'rules of thumb'
    Mine just lasted longer.
    I rode along for 18 months and then was put in a truck.
    Noobs now get a week then get turned out on PMs. It's SAD, SAD, SAD.
    It has taken stumbling across this site and RSES to really launch my education.
    Funny. When I signed in here, I thought I would be the guy that solved everyone's problems...
    Now I realize that I'm just another dummy, running around and trying to make the best of things.
    I've got NOTHING on some of the folks that hang out here.
  12. #15443
  13. #15444
Page 1188 of 2476 FirstFirst ... 18868810881138117811811182118311841185118611871188118911901191119211931194119511981238128816882188 ... LastLast
