Voters
144. You may not vote on this poll
  • june 12
    36 25.00%
  • june 20
    33 22.92%
  • july 1
    27 18.75%
  • july 12
    48 33.33%
  1. #20489
    Nov 2000
    Eastern PA
    lumbar puncture tomorrow
    see if they can find a spine
    Is this the infamous spinal tap that is supposed to be so painful?
    ...seek, and ye shall find;..
    Ecclesiastes 10:2 NIV
  2. #20490
    You got it
    Had one about 8 years ago when I had Meningitis but I was so Load up on Pain meds for the headache I don't remember much of anything about it.
  3. #20491
    Southeastern Pa
    I would ask for those meds again!!!
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
  4. #20492
    I like meds!!!!!!!!!!
  6. #20494
    Vancouver Island, B.C.
    Good Luck with the spinal tap Bret.....I'll say a couple good words for you....My Dad had a number of them and he was a tough SOB but cringed badly every time someone told him he had to have one.....
    Dropped a tree branch across the high tension feed into my property today sometime while I was plowing the neighbourhood....burnt all my phone lines out, and dropped the 13.8KV cutout at the road.......soooooo back out to plow again so the Hydro Truck could lift the branch off and reset the cutout.....sometime in the middle of the night I guess....
    Got the genset alternating heat, light, TV, internet, toaster oven, water pump, and tomorrow the HWT..... Managed to get the router up and running along with the cablevision and router.....the ESSENTIALS....
    "The quality you deserve is not expensive---it's priceless"
  7. #20495
    hi Dug!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  8. #20496
    Quote Originally Posted by supertek65 View Post
    Hey Frank......what are you doing up so late....?
  9. #20497
    looking at porn!!!!!!!!!!!!!!!!
    just wondering?
    do you have a transfer switch at your house that automatically brings on the generator??
    also since it gets so frikkn cold there?
    is it diesel?
    does the diesel genset start okay in the cold/ do you have crankcase heaters in it??
    just wondering??????????
    Quote Originally Posted by Doug Lockhart View Post
  10. #20498
    OBAMA and OPRAH!
    Flying on Obama's private plane, Obama looked at Oprah,
    chuckled and said, 'You know, I could throw a $1,000 bill out
    of the window right now and make somebody very happy.
    Oprah shrugged her shoulders and replied, 'I could throw ten
    $100 bills out of the window and make ten people very happy..
    Michelle added, 'That being the case, I could throw one hundred $10
    bills out of the window and make a hundred people very happy..
    Hearing their exchange, the pilot rolled his eyes and said to his co-pilot,
    'Such big-shots back there. I could throw all of them out of the window
    and make 56 million people very happy.'
  11. #20499
    just wondering?
    is it diesel?
    Male or Female??? Just Wondering...
    I had to put a new service in as the old 150A would not handle the two H/P and B/U heat when I moved in 20 years ago. I used the old 150A SqD as a priority panel basically, then run a new 200A panel in the old panels spot with a 8 circuit/150a subfeed!!!. (Triplex O/H, the mast/conduit drop and old panel busses were good for 200A...it was a dumb hybrid panel of SqD for a few years). I then bought a 8KW and put in a backfeed to the 150A...shut off the main into it and feed my 'priorities out of it'...
    I use the 5000 watt Honda and 8000 watt for the 3Hp flush cart on site as 115VAC won't hold....so I just put stabilizer in the fuel....gas....and it's portable and a 'write off'....
  12. #20500
    mostly females!!!!!!!!
    sweet gen set up!!!!!!!!!!!!!
    I would like to install one here that will support the entire house!
    Ofcourse internet and cable tv are priorities!!!!!!!!!
    does not look like something I will be doing soon!
    guess I will just freeze like everybody else when the ice storm comes again!!!!!!!!!!
  13. #20501
    Just got power on.....yahoo....piss AND be able to flush the toilet....!!!
    Gensets are under $900....get a 16 circuit panel and make a 4/4 SO cord with 4 pin ml twistlock each end (female receptacles in the genny and the wall socket) and your done like dinner for under $1000....
Page 1577 of 2474 FirstFirst ... 57710771477152715671570157115721573157415751576157715781579158015811582158315841587162716772077 ... LastLast
