Voters
143. You may not vote on this poll
  • june 12
    35 24.48%
  • june 20
    33 23.08%
  • july 1
    27 18.88%
  • july 12
    48 33.57%
  1. #13430
    Night guys
  2. #13431
    Nov 2008
    Colorado
    night bret.
  3. #13432
    Denver, CO
    Night Bret, Hello James
  4. #13433
    Nov 2008
    Colorado
    sup jason.
  5. #13434
    NC Coast
    Quote Originally Posted by supertek65 View Post
    I assume you are tripping on high limit?????????????????????
    if so then the boiler is getting too hot, usually the pump is quitting..
    most common service calls on those boilers is either the air switch is out of adjustment/ low gas pressure/condensate probe/o2 out of adjustment.
    look for 5% 02 8 or 9% co2 0-60 ppm co. during high low and mid fire.
    what are you having to re-set??? you never said???
    love you mann!
    1. tripping on high limit on a closed water loop system? It has a small 1.5?amp recirc pump in it (like the kind we used on Water Furnace geothermal systems.
    2. inlet gas pressure if I remember correctly was 10.5" wc LP. not sure what the outlet pressure was suppose to be, Not on the nameplate.
    3. condensate probe? Is that in the drain line or the exhaust flu pipe?
    4. o2 out of adjustment? I replaced the diaphragms in the airmix thingymabob. Nothing else I can do there. One was damaged before I replace them. The soark plug looked like the electrode was an s and not an L. LOL
    reset the on off switch....... when I first arrived. one fault i first had was either flame failure or premature lockout. The other was premature lockout. Last time I went I just went ahead and did the preventive maint stuff. Didnt look for codes.
    I know... Ima dumba$$!
  6. #13435
    Denver, CO
    Good Morning.
  7. #13436
    Southeastern Pa
    Good morning, Bret and everyone!
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
  8. #13437
    windy city
    guten morgen
  9. #13438
    Nov 2008
    Colorado
    Quote Originally Posted by heavymetaldad View Post
    guten morgen
  10. #13439
    windy city
    Quote Originally Posted by james80031 View Post
  11. #13440
    Good morning all
  12. #13441
    Went to the Y Kept up with my old guy with the Cain he was about a 1/2 lap ahead of me when I started and kept the distance even the whole time. got 1 MILE IN and did my 30 lb cures. Was getting dizzy near the end but I did it.
  13. #13442
    Southeastern Pa
    Cool!!!
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
Page 1034 of 2471 FirstFirst ... 34534934984102410271028102910301031103210331034103510361037103810391040104110441084113415342034 ... LastLast
