Results 1 to 10 of 10
    Columbus Ohio
    Heat/Em. Heat/Aux Heat/W2 question....
    If the title wasn't confusing enough, this post might be
    American Standard HP system with a propane gas back up 90+% furnace.
    Honeywell Vision Pro 8000 3/heat 2/cool T-stat
    I cannot for the life of me figure out how to get the Y1 signal to drop out if and when the back up heat is called for.
    I was told that I could avoid the fossil fuel kit by using the VP8000 stat.
    Any advice would help.
    cincinnati, ohio
    something is wrong in your set up.
    Dec 2008
    Are you using a outdoor temp sensor?
    Columbus Ohio
    Quote Originally Posted by BowhunterNC View Post
    No, and I see in the installers guide that you need a OA sensor stat to allow the t-stat to act as the fossil fuel kit. But how is that going to allow Y1 to drop out on a call for back up heat? It reads like it is more of a compressor lock out in low OA temps.
    Dec 2008
    You will lose the call on Y1 if the temp. drops below the setup point (od sensor) and W1 will call turning on the furnace
    Lancaster PA
    Honeywell doesn't have the greatest install instructions, when its comes to their thermostats.
    However.
    Discussions of this type are not allowed in the open residential forums.
    Get your post count up to 15 and apply for pro membership.
    Once accepted, you'll have access to teh pro tech forums. Where this set up has been gone over many times.
    Along with a multitude of other advise and wisdom about many other things.
    Plus, you'll have access to the Pro Educational forums.
    Dec 2008
    The furnace and the heatpump won't run at the same time
    Columbus Ohio
    Sorry Beenthere. I will do this and check out the PTF.
    Dec 2006
    Middle Tennessee
    actually that information is incorrect
    when the system goes into defrost, the furnace and heat pump will run at the same time
    ofcourse, it must be hooked up properly for that to happen!
    and this is why an experienced pro should hook it up
    Columbus Ohio
    Quote Originally Posted by Airmechanical View Post
    Trick answer huh?
