Results 1 to 8 of 8
    Mar 2009
    Purchasing a Lennox 14 HPX Heat Pump
    I would like some verification on a price and a rating.
    A local dealer tells me that the a 3 ton 14HPX-036-230* CBX27UH-036-230+TDR has the following ratings 12.50EER 15.00 SEER & 8.50HSPF and will qualify for the new Tax credit. He's asking $ installed. I'm replacing a 15 year old Janitrol Unit.
    I was surprised that this lower end unit met those specs for that price.
    Need a little verification before signing on the dotted line.
    Thanks!!
    Quote Originally Posted by sonsfour View Post
    Thanks!!
    We welcome questions and discussions pertaining to HVAC for the home. No pricing, no DIY.
    Please read Site Rules Thank you.
    Mar 2009
    Oops, my bad... Won't happen again
    garland, texas
    His numbers are correct. The 14hpx is a low end, the cbx27 is not.
    Mar 2002
    Richmond, Virginia
    Those numbers look correct for zone IV.
    There is nothing more frightful than ignorance in action....Mark Twain
    Mar 2009
    My contractor buys the 14HPX-036-230* & CBX27UH in large quantities and has real good pricing, but is this too low end of a HP and is there a history of problems.
    I don't want to be penny wise and pound foolish...
    Thanks for the advice thus far
    Sounds like one size fits all.
    DC Metro Area (MD)
    The way he said it does.
    The 14HPX is no worse than any other similar grade unit. Copeland scroll compressor, high pressure switch (but no low pressure switch, evidently), and other basic features.
    If it were me, I'd look into at least the Elite XP14, if nothing else for better coil protection as well as the compressor cover and low/high pressure switches. It too would qualify with that air handler, with higher HSPF. Also if you use the variable speed CBX32MV-048 it will also qualify with even better ratings.
