Results 1 to 12 of 12
Thread: TROUBLE SHOOTING T-X-V
03-13-2009, 10:48 PM #1
- Nov 2008
- Hudson Valley, NY
- 179
What are some ways to tell when the super heat is 8 degrees then 0 on a low temp r-404. Tried to open valve couldn't get it right tried to close valve couldn't get it right. Removed sensing bulb noticed that one of the brass screws had made a hole in it could not get power head off so changed valve problem solved. Thought that there was moisture in system all looked good new filter also
03-13-2009, 11:07 PM #2
- Apr 2008
- la puente,ca
- 29
thats good you fixed it kudos. why do you think there was moisture in the system?
03-13-2009, 11:29 PM #3
- Nov 2008
- Hudson Valley, NY
- 179
Why do you think that there is moisture in the system?
Because while the compressor was running, the suction line was frosting up quite heavily and then thawing out quite quickly while compressor was still running and suction pressure was higher than it should have been. That was why I thought there was moisture freezing the valve open.
03-14-2009, 07:56 AM #4
I've never seen moisture freeze a valve open.
Closed, yes, but not open.
03-14-2009, 08:52 AM #5Mastic its whats for dinner!
03-14-2009, 12:39 PM #6
- Aug 2006
- Ohio
- 52
Had a call last night at a Pizza supply wholesaler, with 1 - 5 door section out of a 20 door lineup not feeding. pumped system down and found white crystals in TXV strainers( yes water) also found samething in power element . Had to change drier, clean valve, new power element,change drier, vacuum system and charge back up . Also had to heat valve to get ice threw valve. Gotta love it when you get a leak and someone sets LP control in a vaccum for cut out.
03-14-2009, 01:48 PM #7
This is a good read.http://hvac-talk.com/vbb/showthread.php?t=162325
Educational forums are open.
03-14-2009, 02:07 PM #8
Re-read the OP. Did you lose the power element charge? If so, then you have a different problem somewhere else. That will cause a valve to shut down.
If it is a gas defrost type system, watch your check valves.
03-14-2009, 02:28 PM #9I love the smell of phosgene first thing in the morning:
03-14-2009, 02:31 PM #10
I take that back he did ask for some trouble shooting tips.
A1 Burt A1 Burt is offline
Reply With QuoteI love the smell of phosgene first thing in the morning:
03-14-2009, 09:04 PM #11
- Nov 2008
- Hudson Valley, NY
- 179
CRACKER TECH that was a very good read lot's of good imformation thank's
03-15-2009, 11:33 PM #12
- Feb 2004
- Medford Oregon
- 807
good info on Trouble Shooting TXV's
http://sporlan.jandrewschoen.com/10-143.htm
