Results 1 to 8 of 8
    Mar 2009
    Unable to Find Reference of Payne Model Number
    Hello everybody. My wife and I are in escrow to buy a home. We had the HVAC inspected and tested, and everything is normal. The tech wrote on his report Payne P42PNB036060AAAA as the model number. I have googled, went to Payne's site, etc and cannot find anything referencing this model number. I would like general info, efficiency etc. Any help? Did the tech get the model number wrong somehow?
    Thanks for help, I'm a newbie to HVAC.
    Scott
    Mar 2009
    bump....I'm trying to figure out approximate age of this unit, and maybe some sort of relative efficiency rating. It is a 3 ton unit sitting atop an 1100 square foot home, seems kinda overkill. Dual pane windows, home well insulated, etc. Any direction or help here appreciated.
    Jun 2001
    Louisville, KY
    What's the serial number?
    Perhaps you should have read the instructions before calling.
    Mar 2009
    Tech wrote the serial number as 2902 B(I think) 41120
    Jun 2001
    Louisville, KY
    Week 29
    Year 02
    036 = 3-ton a/c
    060 = 60K btuh heater
    Likely a 10 SEER unit. Can't tell for certain as the P42PNB is not correct.
    Palmdale, CA
    That looks like product # and not model #. From that looks like 3 ton 60K Btuh fau. which would have been 80% afue.
    Dec 2003
    south NJ shore area
    Quote Originally Posted by jrbenny View Post
    Week 29
    Year 02
    036 = 3-ton a/c
    TRY PG9MAB03660 or PG9MAA03660
    GOOD WORK IS NOT CHEAP! AND CHEAP WORK IS NOT GOOD!
    IF YOU THINK A GOOD HVAC COMPANY IS EXPENSIVE. THEN YOU SHOULD TRY A BAD ONE.
    Mar 2009
    Ahhh ok, many thanks for shedding light here. Much appreciated!
