Results 14 to 23 of 23
Thread: HVAC mystery that needs solving
03-12-2009, 12:53 PM #14
If there isn't enough height toget a slope for drainage, add a condensate pump. Who said water has to move down hill?
03-12-2009, 05:14 PM #15
- Feb 2009
- Lunenburg Masschusetts
- 28
dont put a condensate pump in the attic!!!! come winter time you will be freezing the pump reservoir and destroying the mechanism in the pump not including the hose that you will use to pump through. even if you install an electric heat tape you are paying for the electricity the problem is not pumping water it is pitching the drain properly!
03-12-2009, 05:20 PM #16
03-12-2009, 05:23 PM #17
- Mar 2008
- 657
03-12-2009, 05:29 PM #18
- Mar 2008
- 657
damn ya beat me yellow lol
03-12-2009, 11:36 PM #19
Maybe time to change the humidfier pad? Is it a fan type installed on the supply side? Maybe not getting any water and the pad is dried out?
03-12-2009, 11:48 PM #20
not sure if he would have a humidifier in south Lousiana.
03-13-2009, 12:15 AM #21
- Apr 2007
- 84
I'm here in the Bay Area, but lived in L. A. years ago.
L.A. can flirt with frost, but just barely. I don't think anything in an attic
in L.A. has any danger of freezing.
03-13-2009, 06:41 AM #22
03-13-2009, 12:59 PM #23
you are right condensate water has no scale, but it is very acitic water and will break down sheetmetal if it lay on it and dries time after time and humidifier pad would cause that same white scaling dust
GOOD WORK IS NOT CHEAP! AND CHEAP WORK IS NOT GOOD!
IF YOU THINK A GOOD HVAC COMPANY IS EXPENSIVE. THEN YOU SHOULD TRY A BAD ONE.
