Results 1 to 7 of 7
    Mar 2009
    Help, which package unit is better
    I live in phoenix and am replacing a rooftop packaged unit. I've received quotes on Carrier Infinity 15(50XT0603TP) and a Carrier Performance (50VT0603TP).
    Infinity system - 14.5 SEER, 11.0 EER
    Performance system - 14.2 SEER, 12.0 EER.
    The price difference is $. Is it worth the $ to upgrade to the Infinity system?
    thanks,
    Rich
    Apr 2008
    Alberta Canada
    Yes
    Quote Originally Posted by richz View Post
    thanks,
    Rich
    I would better features on the Infinity system.
    Do it right the first time.
    DC Metro Area (MD)
    Do you want the 30% up-to $1500 tax credit on the Performance unit (meets specs at 12 EER, 14 SEER, 8 HSPF), or the Infinity system's capabilities? The Infinity has a variable speed blower and 2-stage cooling/heating, which helps with comfort and with humidity, but is humidity a big problem for you?
    Mar 2009
    I'm more interested in the best system for the money ( efficiency and longevity). We do have humidity for approx. 2 months during
    our monsoon season.
    Is the two stage cooling more efficient? Save $$?
    Thanks guys.
    2 stage A/C is more for comfort then savings.
    It will save a small amount.
    It will be able to keep your humidity lower then a single stage.
    Mar 2009
    So, the 2 stage compressor probably wouldn't be a good return on the $ investment.
    Should I go with the performance model instead and save the $?
    No prices in post.
    Depends.
    During your high humidity season. Do you turn your stat lower when the humidity gets high in the house.
    If so, the 2 stage will save you on those months.
    Its not a question of will it save you anything.
    More, what is your comfort worth to you.
    If its not worth much, get the Performance.
    PS: No prices in post. Not even upgrade prices.
