Results 1 to 7 of 7
    Westmont IL
    90% vent booster ?
    I am working on 90% furnace vented with 2 inch pvc up about 35 feet through two other condos. Thing is the inducer fan can't build enough pressure to activate the pressure switch. Running new pipe is close in impossible. I was wondering if adding a booster fan is possible.
    How old is it.
    Did it work when first installed.
    Westmont IL
    Less then a year. It worked well all winter.
    Since it worked most of the winter. Its probably not the inducer its self.
    May be some other restriction.
    What do the install instructions say about that vent length.
    You need to apply for pro membership.
    Westmont IL
    It is a piss poor install.(NOT MINE) It is a super fast condo conversion flip in Chicago. The directions say a 20 foot max and it goes for well over thirty feet. The pipe is clear of nests and the like. I was just hoping the give a little boost.
    Westmont IL
    Plus i just go all of my posts. My pro app should be done tonight. Thanks
    As far as I know, there is no draft booster for a 90% furnace.
