Results 14 to 17 of 17
    Mount Airy, MD
    Thread relocated to "Tech to Tech"
    Nov 2005
    Belgium
    Quote Originally Posted by Firerestoration View Post
    Liquid return during the running cycle. More commonly known as refrigerant flood back. The expansion valve plays a part in all the conditions here whether directly or indirectly this is obviously because the refrigerant can only really come this route.
    What about the very special oil separating system of a VRV? Is it not too complex compared to common oil separators? What's the advantage of this system?
    Mar 2009
    South Africa Cape Town
    In short, my findings.
    The original VRV 2 did not have a suction accumulator installed, this caused liquid to wash oil away and eventual seizure of compressor. The compressor would then draw locked rotor amps and blow the inverter board. All models after the RXY**MY1 had suction accumulator installed as far as I know.
    I would call that Daikin a rubbish unit.
    Similar situation on a recent job, four Fujitsu units with tandem compressors, 6 comoressors died. Originally No overload installed in power circuit of compressor, bi-flow drier filter is located in a tight corner with sensor cables around, leaving a hard time to the service people who have to struggle on how to torch it off without burning his eyebrow and cables.
