03-06-2009, 09:08 PM #1
- Mar 2009
- Under the brilliant Midwestern Moon or Sun (depending on time of day).
- 135
Simple question ... does Trane Pub. No. 22-1813-03 apply "only" to HeatPumps?
Does Trane Pub. No. 22-1813-03 apply also to A/C Condenser (split) systems?
03-06-2009, 09:30 PM #2
Professional Member*
- May 2007
- DC Metro area
- 3,235
I'm posting the link so others here know what you're talking about: http://trane.com/CPS/Uploads/UserFil...3_09012008.pdf
Not sure what you mean "apply to" heat pumps only? The 2/4TXC coils are used with both air conditioners and heat pumps.
03-06-2009, 10:02 PM #3
- Mar 2009
- 135
You indeed helped answer my question, simple as it was. I'm new to reading HVAC things & about Coils et cetera.
But for further explanation & for other readers, the title of the publication in question is as follows:
Aluminum Cased and Uncased
Heat Pump / Cooling Coils
1 1/2 - 5 Ton
2/4TXA, 2/4TXC, 4TXC-CC
Heat Pump /Cooling Coils for R-22 and R-410A
And where it says "Heat Pump / Cooling Coils" ... I simply wasn't clear if it meant ... the cooling coil of the heat pump, or more properly ... heat pumps and cooling coils.
That was elementary I know. But thank you indeed for helping me to learn.
03-06-2009, 10:10 PM #4
- May 2007
- DC Metro area
- 3,235
I think the wording in the heading of the document is unclear myself, so if I provided misinformation hopefully someone will clarify.
However I can tell you that the model number 4TXCB036BC3, for example, is a rated match on the AHRI database with both a heat pump and an air conditioner. The letters after the "BC3" may designate further info regarding the setup. So indeed the 2/4TXC coils are used with both heat pumps and air conditioners. Yes, I'm just thinking, or typing rather, out loud.
03-06-2009, 10:18 PM #5
- Mar 2009
- 135
I do wonder about something else to though, if anyone out there knows. Which is:
Is there a newer version of Trane Pub. No. 22-1813-03 that's out now, or is that the the most recent publication for those coils?
Hmmm.
03-06-2009, 10:42 PM #6
- Mar 2009
- 135
Per my other posting (link below if interested), my present system setup likely has one of the following basic coils, with the two bolded ones most likely ... TXA-C, TXC-C, or TXC-S.
I have not torn into my coil box yet to identify it specifically. It doesn't have a door, but it is taped up w/screws on part of sheet metal. Been holding off on that, I have severe arthritis.
http://hvac-talk.com/vbb/showthread.php?t=238892
