Results 1 to 8 of 8
03-06-2009, 04:49 PM #1
- Jul 2006
- 528
Contractor swapped Condensing unit
As stated in earlier post's, I'm having a 3 ton 14 SEER HP installed this weekend.
The equipment was Goodman model SSZ14031 condensing unit with matching AHU model AEPF303616. He delivered the the equipment today for tomorow's install. The issue is, the condsensing unit is not the SSZ14031. It's an Amana ASZ140361. The AHU P/N is stil the goodman AEPF303616.
The installer say's it's an "upgrade". That the price of the install would remain the same. I assume that's a good thing. My understang is that Goodman/Amana are related?
What is the difference between the condensing unit's?
With the original goodman part's I could go to the ARI sight and get a ARI-Certified Performance certicicate that I could print for the tax credit.
With the ARI number the contractor gave me 1077417, I could not find anything on the ARI sight using this number in the search box. Can any one tell me if this is a certified match for the ARI certificate?
03-06-2009, 05:03 PM #2
Try 1277881 on AHRI
The Amana is definitely a great upgrade. Quieter, more compressor protection.
http://www.amana-hac.com/Home/Produc...1/Default.aspx
03-06-2009, 05:15 PM #3
- Jul 2006
- 528
Try 1277881 on AHRI
Thanks BaldLoonie. That number worked.
03-06-2009, 05:17 PM #4
Professional Member*
- May 2007
- DC Metro area
- 3,223
You got a better unit.
03-06-2009, 05:36 PM #5
- Jul 2006
- 528
[QUOTE=BaldLoonie;2707832]Try 1277881 on AHRI
It say's it has a two speed condensor fan motor. Is this adjusted by the installer or is it an internal automatic circuit that determines the speed? And, how does this help in the operation of a HP?
03-06-2009, 05:38 PM #6
- May 2007
- DC Metro area
- 3,223
The condenser fan motor isn't what matters for dehumidification; the indoor motor is what matters, and you have a variable speed motor. The Goodman is probably a single speed condenser fan motor.
03-06-2009, 05:40 PM #7
- Jul 2006
- 528
[QUOTE=RyanHughes;2708382]The condenser fan motor isn't what matters for dehumidification;
I was not clear in my last post. I'm aware of the indoor AHU function. I should not have grouped the question with a bad thought. I'll go "fix" it now
03-06-2009, 06:11 PM #8
- May 2007
- DC Metro area
- 3,223
I think it's controlled based on outdoor ambient temperature, but I could be wrong. Nice to have, but not all that important. Would help with noise, but not substantially.
