Results 1 to 13 of 23
    Oct 2005
    Omaha, NE
    Advice needed: Most reliable 80% eff Furnace
    I know this topic has been discussed a million times here, but the more I read the more confused I am!
    My needs are simple: 80% eff and reliability.
    1. 80% efficiency
    (Too complex to explain but I want 80% eff furnaces)
    2. Reliability
    (Yes, I want a reliable furnace; not 5-6 service calls per winter!)
    - The Lennox G40 or G50 seems OK but reading this forum, it seems like people have problems with it?
    http://www.lennox.com/products/overview.asp?model=G50
    - Carrier 80% seems OK too? But which model?
    http://www.residential.carrier.com/p...as/index.shtml
    - Goodman GMS8 Series 80% seems to be the most used in this forum:
    http://www.goodmanmfg.com/Portals/0/pdf/CB-GMS8.pdf
    So, please help! I need feedback (good or bad) from homeowners and pros, what 80% eff units they have and the pros and cons.
    Yes, the furnaces will be installed by HVAC contractors but I need feedback from people.
    TIA
    Two-Story Home + Basement
    Furnace A: 1991 Tempstar 80% eff 120K BTU (1st floor and basement)
    Furnace B: 1991 Tempstar 80% eff 80 BTU (2nd floor)
    Mar 2009
    los banos CA
    i would go with goodman it will last and it also has a more plesent price tag. plus they have a few differ sizes in 80% so garage attic or closet you have a choice. also i ve found that if you do have an issue they are realy good about tech support and returning phone calls.
    The one that's installed correctly, will be the most reliable.
    Mar 2009
    los banos CA
    as homeowner and mom money matters alot for me this would be my choice as a senior tech this would also be my choice if price is not an issue go with a trane.
    Mar 2009
    los banos CA
    install is a huge part of good operation so true
    Oct 2005
    Omaha, NE
    Quote Originally Posted by the dangling wrangler View Post
    Could you help me with the checklist for good install so I can go over this with my HVAC people to be sure they do a good job?
    You might want to use This to help choose a contractor.
    Quote Originally Posted by cn View Post
    I'd say, use what beenthere said. My checklist will differ from someone elses. And the beat goes on.
    Oct 2005
    Omaha, NE
    Thanks,
    My Tempstar furnace during the last 18 years of operation, other than annual service by HVAC company, the only thing that was ever changed was the Ignition Module (? spelling) according previous owner's maintenance records!
    Part of me wanting to use Tempstar again because this unit runs well for 18 years straight!
    So, I do need recommendation re brand (Lennox vs Carrier vs Goodman vs Tempstar) and model number please!
    Thanks,
    Once again, it's all in the install.
    IMO, I wouldn't get an 80% furnace that didn't have a variable speed blower. All the manufacturers you listed make one. It will be a slight price bump but you'll save electricity during both heating and cooling seasons and it will be quieter assuming properly sized ductwork.
    chicago suburbs
    if you have had good luck with Tempstar why change?
    Aug 2008
    Booneville, Mississippi, United States
    go Tempstar
    T8MPN model, works great!!
