Thread: Lennox system
    Cedar Grove, Wi-Sheboygan
    Lennox system
    I just returned from my anunts home down in OK, last week and the last time I was there I found several code violation and basically saved my Anunt & uncles lives, this time around I was there and the filter needed to be replaces as I noticed the airhandler running more than normal and working harder than it needed to so I checked the filter and sure enough it was way past due, what a difference that made. Now after changing the filter I also noticed the airhandler is quite loud even in low fire and low fan speed operation, the airhandler sit up on a box in a closet and the box (return air) is about 3' sq and 3' high which is directly opposite the intake grille on the other side of the wall and all supply air is ducted in the ceiling but the unit is just way nosiy IMO. Would the use of turning vanes help there situation or would they need to have some work done in the return box which the bottom of the airhandler sits directly on the top of this box ? Suggestions ? The stat is one of those lennox type, and I believe there system is one of the top of the line airhandlers/HP's.
    Northeast Ohio
    I never checked to see just what size system they have but am guessing it's probably a 4 ton system, would it be possibly the blower setting on the airhandler is set too high for the size duct work and tonnage they have ?
    burlington county n.j.
    could be blower speed to high, could be return grills to small, could be return box to crappy, could just be return grill so close to blower.
    maybe turning vanes will help, maybe they won't. maybe insulating the return box would help, maybe it wouldn't...................
    you have been around long enough to know internet diagnoses suck.......
    Lancaster PA
    Quiet Vanes might help.
    Sep 2006
    run away
