Results 1 to 8 of 8
    Nov 2001
    Hammock Filter Material
    Recently purchased a custom made aluminum frame filter with screen and hinged sides. Am I correct in assuming that the direction of air flow should be first through the filter material and then screen with screen closest to coil? Material is 1 inch spun fiberglass and is only Merv 2. Is this OK to use on variable speed handler?
    Fox Lake IL
    I would into putting a better filter in.
    TX
    sure won't impede the airflow!
    I don't know
    That is correct. Fiberglass media is practically worthless though.
    Nov 2001
    So what would the recommended material to be used in this frame? Pleated media?
    Nov 2001
    Isn't hammock spun fiberglass same as inexpensive bue $1 filters? Is present hogshair filter better than cheap disposable filters?
    I don't know
    I like the 3M Hammock media - expensive, but superior to fiberglass and not too restrictive. (http://shopping.sympatico.msn.ca/spe...ter&fulldesc=1)
    Trublue also makes something similar.
    Nov 2001
    I ordered some pleated material from air sponge. Will have to cut and fit to frame.
