Page 1 of 5 12345 LastLast
Results 1 to 13 of 57
    Unhappy disappointed in NATE techs
    There are only 2 HVAC companies in my area that have NATE-certified techs, so I called them both out to see why my 2.5 ton, 5-year-old, 10 SEER Ruud heat pump is sending vibrations into the house via the line set. One tech says the compressor needs to be replaced. The other says no, the compressor is not the problem, it's the reversing valve. Why can't 2 highly qualified techs agree on a diagnosis?
    Jun 2001
    Louisville, KY
    Why do doctors give different opinions of the same symptoms?
    Because NATE doesn't prove sheit about a tech's abilities in the field.
    Houston,Tx.
    Nah, never mind to easy, I do at least like a challenge. here's an old hillbilly idea, is there only NATE tech company's available in your area? if not you might actually find someone with 35 years exp. that is not Nate certified, that might have a clue. I know the possibility seems impossible, but give it a try, you never know.
    Quote Originally Posted by jrbenny View Post
    Is that really a fair comparison? I mean, heat pumps were designed and built by man, but our bodies were designed and built by God.
    Quote Originally Posted by dandyme View Post
    So what does prove sheit? How can I find someone who I can trust?
    Jun 2006
    New Jersey
    Quote Originally Posted by charles2 View Post
    Just because a company says there NATE certified, doesn't mean all the techs are NATE certified.
    Just because a tech is NATE certified, doesn't mean they are NATE certified with heat pumps.
    Just because 2 techs are certified, doesn't mean they are going to agree a solution.
    With that said, I just had two lincensed engineers out to a job sight, to look at a boiler. And guess what they had two totally different solutions to the problem.
    Why don't you elaborate on your issue, and maybe some one can point ya in the right direction.
    PS-I'm all for NATE certification, but to be certified you only need one. There are 21.
    Houston,Tx.
    Do you have an old Faithful?
    Oct 2008
    Coming to a town near you soon
    Heat pumps cant tell us where it hurts and they don't tell me if its feeling better when I give it medicine. The only ones that talk to me just tell me dirty jokes.
    I think it's ludicrous to suggest that a company can be trusted just because they are listed in the yellow pages. :-(
    Were any of those companies, the company that installed it?
    If not.
    Call the installing company.
    Jun 2001
    Louisville, KY
    He means that you can shop for a dealer.
    He didn't indicate that a phone book ad equated to someone that is trustworthy.
    Sheesh.
    I have a team of Doctor Highly skill and recognized in their Field that look at the same test and sometimes and tell me different results.
    And most customer don't want to hear it could be a b or c I can't say for sure (even thought thats the truth) this a good ex of that.
    Trust me I've leaned to expected that from Doctors. a b or c.
    Oct 2008
    Good point, Its usually A,B or C and we'll try this and if that doesn't work we'll try something else.
