Results 1 to 11 of 11
Thread: Recovery Cylinder Capacity
02-25-2009, 05:12 PM #1
What method are you guys using to determine the capacity of your recovery cylinders?
HVAC PRO IN THE MAKING
NATE's:
Gas Heat Service/ Installation
Air-to-Air Heat Pump Service/ Installation
Air Conditioning Service/ Installation
02-25-2009, 05:16 PM #2
I have always used the stamped gross weight on the tank. Is that wrong?
02-25-2009, 05:19 PM #3
yep lol. thats part of it but theres a way of determining what percentage of the cylinder is fluid at certain temps etc so you dont go beyond 80% liquid in the thing.
ive attached two pdf charts that i dug up from last year. theyre both different and i think one is out dated or something.HVAC PRO IN THE MAKING
NATE's:
02-25-2009, 05:26 PM #4
I have always used the WC * .8 + TW = total weight when 80%.
02-25-2009, 07:29 PM #5
dont ya just fill it till it cant fit no more
What cant be done correctly shouldn't be done at all
02-25-2009, 07:38 PM #6
02-25-2009, 07:51 PM #7
62lbs and 42lbs. max weight on the two sizes that i use. that's how i know. fill it till it is there or close to there.
hey profiler, why you doing installation NATE's????
if you do the service NATE's they'll give you the installation credits
http://www.youtube.com/watch?v=nFl0n...ture=endscreen
02-25-2009, 07:52 PM #8Global Warming or: None like it hot
No pleasure, no rapture, no exquisite sin greater... than central air. -Dogma
02-25-2009, 08:03 PM #9
Got this somewhere...
Not sure where I found this formula but here it is.
To convert to refrigerant capacity:
Maximum allowable gross cylinder fill weight is 0.8 x water capacity x specific gravity of
the refrigerant recovered @ 77°F/25°C + the cylinder tare weight.Steamfitters Local 602
02-25-2009, 08:07 PM #10
You silly geese...ive only taken 2 exams plus core. What makes you think im actually taking the installation exams? I took the gas heat service and heat pump service. 21 certs total i believe including cores and ive knocked out 8 of em. I put service/ installation on my thingy cause ive got boph.Last edited by Profiler; 02-25-2009 at 08:22 PM.
NATE's:
02-25-2009, 09:07 PM #11
