Results 1 to 8 of 8
    Question EPA and NATE requirements
    Is it within EPA and NATE requirements to allow refrigerant to spray from your hoses for a couple of seconds when you disconnect your gauge set from the service valves?
    Fort Worth, TX
    NATE does not regulate refrigerants.
    Building Physics Rule #2:
    Building Physics Rule #3:
    A purging of the manifold hoses is permited, within reason.
    Apr 2004
    Palmdale, CA
    When disconnecting your hoses some release would be di minimis release. It's been a while since the EPA cert test but I remember this being legal. It is still best to use low loss fittings.
    Apr 2004
    Palmdale, CA
    Sorry had to add this.
    4) Small releases of refrigerant that result from purging hoses or from connecting or disconnecting hoses
    to charge or service appliances will not be considered violations of the prohibition on venting.
    However, recovery and recycling equipment manufactured after November 15, 1993, must be
    equipped with low-loss fittings.
    http://www.epa.gov/ozone/title6/608/608fact.html
    de minimus
    true knowledge exists in knowing that you know nothing.
    Jul 2001
    replace your hoses, or buy low loss adapters.
    heh, you looking to get a tech in trouble that came to your house?
