Results 1 to 10 of 10
02-24-2009, 11:42 AM #1
New Guest
- Feb 2009
- 2
BACNet MS/TP Troubleshooting/Testing
Has anyone found a good scan tool or utility for testing/troubleshooting a bacnet mstp trunk? I need something to scan a trunk for JCI bacnet devices as well as others. Thanks
02-24-2009, 12:00 PM #2
- Oct 2008
- Atlanta, GA
- 115
I have a great tool. Do you work for JCI? Email me.
02-24-2009, 12:13 PM #3
New Guest
- Feb 2009
- 2
nicholas.c.deal Is that you??
02-24-2009, 12:49 PM #4
Waiting Email Confirmation
- Nov 2007
- 78
Nickdeal,
Can I have that same info I am currently looking for the same device.
02-24-2009, 12:57 PM #5
- Oct 2003
- Michigan
- 665
Beware of the prophet trying to make a profit.
There is less oxygen from knee level to the floor! Check it out next time you tie your boots.
02-24-2009, 01:40 PM #6
- Oct 2008
- Atlanta, GA
- 115
Yes that's me. Just email me and I'll send you a zip.
02-25-2009, 07:58 PM #7
- Oct 2005
- 82
I have found Polarsoft to have good, independent, BACnet utilities for scanning and interpreting a BACnet network. They have a program called BACnet Quick Test that will work on IP, Ethernet, PTP, and MSTP networks. Go to www.polarsoft.biz. If you are looking for something that is not affiliated with any control company and will give you a good third-party answer on a BACnet issue, Polarsoft will help.
02-26-2009, 06:44 PM #8
- Nov 2005
- Shreveport, Louisiana
- 2,240
I work for JCI also and Monday I am going to a customer site to do the same thing but with TEC2600's
UA Local 141
02-27-2009, 01:25 PM #9
Berg2666,
Been following your post regarding your problem with mixed JCI and other mstp bacnet devices... I am facing similar thing, only this is FX16-Bacnet with 3rd party FCU controllers connected to an NAE; both work fine with NAE if the the devices on the ms/tp bus are of same type, the online/offline issue only occurs when FX16's and these 3rd party devices are connected together.
Hope you can give any feedback here if ever you're successful in troubleshooting this comms issue...
Ohh, and I apologize to the OP for the small Hijack...
03-01-2009, 06:51 PM #10
- Sep 2008
- 51
Hi, Has anyone connected a Carrier XA30 (or similar) chiller Bacnet MS/TP controller to a JCI MS/TP trunk.
I have encountered some interesting problems.
